0 Members and 123 Guests are viewing this topic.
flygfantast
4AAD92 SE-KLR, Cessna 172N Skyhawk, c/n 172-71522, Hässlö Flygförening
Niklas
Cable: Ecoflex-10 (10m+1m)
see some database inconsistence regarding Aquila A210 / A211 / A211GX airframes in the attached picture.
Unknowns from Saturday:
38C37C  02AGZ http://www.airport-data.com/aircraft/photo/001111453.html
39B246  FHMSG
3D2C5E  DEPBA https://planefinder.net/data/aircraft/D-EPBA
3D5D16  DFHMS in db (if donwloaded, but does not populate for some reason)
3FF0CF  DMTTO no further information
3FF0D2  DMBKM still no luck with the details
3FF209  DMGCL no further information
3FF2FB  DMWCS no further information
3FF3DE nothing more
7403FF nothing more
Regards Ingo
Thank you for pointing out my error, the 4 now the same as the others.
There more almost 235.000 entries in the airframe database. I'm quite confident that there are more glitches like this one in the db. Incidents as with the Aquila can help to fix some of them.
Ingo,
38C37C,02AGZ,,Aveko VL-3 Sprint
39B246,F-HMSG,525A-0033,Cessna 525A CitationJet CJ2,Aeromecanic
3D2C5E,D-EPBA,202LSA,Breezer Aircraft Breezer
3D5D16  DFHMS are you stating that it is still not populating and it is in your Navdata?  Cant understand this.
3FF2FB,D-MWCS,UL117,Breezer Aircraft Breezer,
Nothing on the others
Many thanks
I would expect there to be and it would help if more pointed these out.
Thanks X RE N377CJ, will add it back into the d/b.
An eyeball for confirmation of C5-AAH being 09A039 seeing that there was only two pings would be appreciated.
#1929
I downloaded the db from server about a hour ago on my laptop to check the Aquila entries. I used replace db option. In this db D-FHMS is in. On my 24/7 Server PC I haven't ran a db download this weekend. As long as the populate function is working I'm doing a db download once per month.
On the 24/7 PC D-FHMS did not populate, although I have ran several populate cycles since D-FHMS was added to server db. It seems, that for some reason populate does not work for some airframes.
Michel
Alan,
TRA75C EHAM-LGMK
Michel.
silverjet102
Good afternoon,
Route table update
VLM17WL = VG417 Waterford-Luton
Cameron
silverjet102
Good afternoon,
Another route update
ANE8404 = Vigo to Luton
ANE8405 = Luton to Vigo
Cameron
