0 Members and 121 Guests are viewing this topic.
X
We believe the unknown Pakistani Mil code 7602F1 might be EYE-77(2) CL60, due in Luton tonight
X
Thanks X, hopefully we will get some confirmation.
X
#1982
I have just been informed the CL60 due LTN might be using 761725 but that is/was 1003 Citation. EYE77 used to be a HA4T. Pakistan usually stick reg and hex together... Hopefully those at LTN will confirm! If it is 761725 I have no idea about 7602F1.
X
Afternoon Alan, unknowns from Monday:
3C17CC  AIB736A http://xfw-spotter.blogspot.de/2015/07/a321-231sl-spirit-airlines-d-ayah.html
D-AYAH A321 Airbus Test Reg
3D2023  DEKKP http://www.piper-germany.de/fileadmin/Dokumente/de/angebote_demonstrator/Archer-LX_2015_D-EKKP_G1000_DE.pdf
3E480A  DISMC http://www.eurocityflightschools.de/Flugzeugcharter_Stuttgart.html
3ECBB8  DKSCM http://mitgliederportal.segelfliegerclub-muenchen.de/SitePages/Homepage.aspx/scm/index.php?id=14
3FF2BB  DMTEZ no further information
3FF3E9  DMKZZ no further information
3FF3EF  DMUVH http://www.aero-clubidar-oberstein.de/Flugzeuge/Flugzeuge.html (could fill some more gaps)
3FF419  DMERE no further information
400977 no active/valid airframe found
451DB8 nothing more
479EE3 nothing more
49C002  OKMUU this question is: which number after the second U...
502C66 nothing more
885A63 nothing more
MILs:
   3E76E9        2015/08/03 14:14:13
* 3E9138  GAF120                                                         2015/08/03 07:35:20
* 3EA0CF  GAF142                                                         2015/08/03 06:21:54
* 3EA0CF  GAF142                                                         2015/08/03 10:22:12
   3EAA36        2015/08/03 07:32:52
   3EAA36        2015/08/03 08:33:15
* 3EB034        2015/08/03 07:39:48
* 3EB184        2015/08/03 07:35:18
* 3F438B        2015/08/03 15:41:37
* 3F777E        2015/08/03 08:22:52
Regarding D-EBPG from yesterday: My laziness  hoped for a brainstorm at your end. As it didn't came I had to write the text.
Regards Ingo
jim_stockwell
Hi Alan
Do you have any idea of the arrival time of the Pakistani? I will keep an eye open for it to try and clear up the hex coding and flight i/d assuming there is one. If it arrives after dark, then the type maybe impossible to determine.
After your comment on the weather, the full wet weather gear has gone into the bag!
jim
X
761725 is till 1003 as far as I am aware but these thing can change in an instant.  The original EYE77 is now N786ZS so its possible they have a new one.  Hopefully we will get an eyeball report either on here or on mode-s or one of the local forums for Luton.
No idea Jim other than what was stated by X.
Wise move with the wet weather gear.
shouriken
Some little corrections:
1. in the aircraft table
YR-RAG - the owner is "Regional Air Services" (ICAO code RTZ). I think you can delete the miscode A48591 for it because they doesn't use it anymore.
YR-SCB - the owner is "Regional Air Services"
2. in the airlines table
"Regional Air Services" ICAO code is RTZ.
Thank you.
Liviu
A.net JetPhotos.Net
RadarBox
Afternoon Ingo,
My brain doesn't storm much these days, got to be taken by the hand!
3C17CC,D-AYAH,VARIOUS,Various A321 Airframes,Airbus Test Registration
3D2023,D-EKKP,,Piper PA-28-181 Archer III
3E480A,D-ISMC,T30300245,Cessna T303 Crusader,Eurocity Flight Schools
3ECBB8,D-KSCM,,Glaser-Dirks DG-1001T,Segelflieger-Club München
3FF2BB,D-MTEZ,0004-6232,Ikarus C42 Cyclone
3FF3EF,D-MUVH,,Tecnam P92 Echo Classic Del Luxe,Aero-Club Idar-Oberstein
Nothing on the others and mil tac added.
Many thanks as always
Many thanks Liviu, amendments made to the aircraft and to the airlines table.
X
* 7335B1        2015/08/04 20:00:08
7335B1 decodes to EP-MMQ A346 Mahan Air but c/n not confirmed as yet
X
X
Hi Alan/Jim
The Pakistani was reported travelling via Ankara but no idea of arrival time in LTN
X
jim_stockwell
Hi Alan
The Pakistani landed at Luton at about 2050. It had a hex of 761725 and a flight i/d of PAEYE77 but no other info I'm afraid. It looked like a Challenger light was poor. I see it is reported as a 605.
Jim
X
Planespotters.net gives it as c/n 449
Many thanks for the info Jim, not heard anything yet.
