1 Member and 26 Guests are viewing this topic.
#1995
X/Jim
761725 confirmed as EYE77 CL605 c/n 5995.  Nothing on 7602F1.
Just on case you go looking for it 761725 has departed Luton and is over the Adriatic as this time.
Afternoon Alan,
EZY85RU : LEAL-EGGP
WZZ2389 : LHBP-LEMG
WZZ2390 : LEMG-LHBP
jim_stockwell
I have seen on several sites that the c/n of EYE77 is 5955, not 5995 as above
Jim
shouriken
Liviu
A.net JetPhotos.Net
RadarBox
That was quick Liviu.  Many thanks for the info
Thanks Jim,  I got the info from mode-s, now changed
Liviu,
FBA is indeed the ICAO code for Fly Baghdad. You should have the logo for it in your logos folder, if not it's in reply #3301 of the logos thread.
Afternoon Alan, unknowns from Tuesday:
3C17C9  AIB729A
another Airbus A321 test reg (seems that they got a new area for testfilghts, which is in my range)
http://xfw-spotter.blogspot.de/2015/07/a321-211sl-tam-d-ayae-pt-xpi-msn-6729.html
3FF34A  DMWDC no luck with the details
4008B7 G-OOAP no active airframe found
89600C nothing more
MILs:
* 3E823F  GAF128   LPLA-EDDK                                             2015/08/04 06:37:24
* 3E829F  GAF640                                                         2015/08/04 06:57:39
* 3E829F  GAF640                                                         2015/08/04 10:51:00
   3E8A4A        2015/08/04 08:47:15
* 3E92A3  GAF779                                                         2015/08/04 10:57:10
* 3E9CFC        2015/08/04 09:10:25
Regards Ingo
Afternoon Ingo,
3C17C9,D-AYAE,VARIOUS,Various A321 Airframes,Airbus Test Registration
Nothing on the other and the mil tac added
falcon_nl
Unknown :   3DDF6A   DHEVY
Hi falcon
Added it to the d/b yesterday 3DDF6A,D-HEVY,1684,Aerospatiale AS350 B Ecureuil,
shouriken
QuoteFBA is indeed the ICAO code for Fly Baghdad. You should have the logo for it in your logos folder, if not it's in reply #3301 of the logos thread
Thank you Ian.
Liviu
A.net JetPhotos.Net
RadarBox
