0 Members and 23 Guests are viewing this topic.
Thanks for the correction Liviu, YR-BAJ is in the d/b correctly.
shouriken
Yankee India, not Yankee Romeo :)
Liviu
A.net JetPhotos.Net
RadarBox
Sorry, Liviu, its in the d/b correctly as YI-BAJ :-)) Mistake on here.
Michel
Alan,
TAR881 EHAM-DTTA
Michel.
X
Indian unknown
* 80066D        2015/08/07 07:38:04
X
Afternoon Alan, Unknowns from Thursday :
3CD062  GFD6 either a replacement for the crashed LJ of GFD or a bad packet received.
3D29BA  DEOBA https://planefinder.net/data/aircraft/D-EOBA
3E7567 Nothing more  or MIL
3FF36A  DMYCH no further information
465200  RAGE flight id suggests MIL
49C110  OKUUA85 Seems to become a daily guest
4CA29B was EI-DJW nothing .about a new one
E491AD  TAM9951some Airbus on delivery and therefore already added by now I guess
MILS
* 3E8372  GAF011                                                         2015/08/06 08:35:23
* 3E9829  GAF383                                                         2015/08/06 11:48:07
* 3E9829  GAF383                                                         2015/08/06 12:43:00
   3E9B9A  GAF022                                                         2015/08/06 08:52:11
* 3EBF23        2015/08/06 07:37:40
* 3F5D68  TALON51                                                        2015/08/06 13:35:18
* 3F68D3  GAF127                                                         2015/08/06 07:42:22
* 3FEFCF        2015/08/06 11:55:08
Regards Ingo
X
80066D,VT-CSL,57045,Bell 429 GlobalRanger,Chemplast Sanmar
Hi Ingo,
3D29BA,D-EOBA,027LSA,Breezer Aircraft Breezer
3E7567 mil tac
465200 unknown to me
E491AD PT-XPH A321 added last night out of XFW
Nothing on the others and mil tac added.
X
764D08        2015/08/07 17:46:00
Unknown 764D08 which decodes to AP-SHH, I believe this aircraft was the original EYE77 reregistered, but will confirm
X
X
I had Mahan A346 c/n 449 as EP-MMI not MMQ, but could be wrong as there is confusion as to which is which on these A346's
X
superspotter
Hello once again from sunny Lagos;
Hexcode 0640FA is NAF-030 Nigerian Air Force Do228, callsign NGR030, regards clive.
Blueboy
Hi Alan, picked-up Hex A3967A which decodes as Hawker 900XP N330GW ex. A6-PJB
J.D
X
I jus noted that I have EP-MMI and  EP-MMQ in the d/b as c/n 449.  My d/b doesnt have either in yet but I googled and found EP-MMQ as c/n 449 with Planespotters and FR24,  However googleing EP-MMI gives it as c/n 499 on FR24, Air fleets and Planefinder.
I will therefore delete the c/n from both until I can get something concrete o nthese two.
flygfantast
4AB4B9 SE-MEY, SportStar RTC, c/n 2015709, Halmstad Flygklubb
4AB529 SE-MII, Tecnam P2008JC, c/n 1040, Aviation Network ANM
Niklas
Cable: Ecoflex-10 (10m+1m)
