0 Members and 29 Guests are viewing this topic.
X
I don't get 764D08 to decode.
The original EYE77 HA4T c/n RC-032 is now N786ZS.  AP-SHH was c/n RC-021 ex HBC21 and A6-SHH now A6-SHH again and used 762043 when HBC21.  I stand to be corrected onboth counts
Many thanks Clive, I have not found a c/n for it either.
this MIL hasn't populated: 3E8372  GAF011                                                         2015/08/06 08:35:23
Please re-check. Thanks!
superspotter
It's in our Db Alan as c/n 8219?
regards clive.
Yes it is in the d/b OK Ingo
Got it now Clive, no idea why I couldn't find it previously.
Many thanks
superspotter
I have been receiving hexcode 0641B8 for the past two days on the ground here in Lagos. After posting a log on the forums, I have been told that Med-View have taken a 767 on delivery which indeed I saw sat here today but didnt read the reg off. Putting two and two together, I am assuming that this hexcode will be this 767 which is registered 5N-BQN c/n 26261 and it is in full Med-View colours and no doubt is being readied for the Hadj. Do you have anything on this Alan?
regards clive.
Skyliner have 5N-BQN as on delivery 01aug15 GYR-ATL, a B763 c/n as you detail ex XA-UTC so I expect that it the one.  Hex first picked up on the network 1/8
Many thanks JD, just registered yesterday.
superspotter
OK good, I will be getting a picture of it in the morning!
AoD
AUI129      UKBB - LFPG
CGF5794    LBSF - EDDK
DLH7MA     EPPO - EDDM
EXS1U       EGNM - LTBS
NAX8DW    EPWA - LEBL
PRI560       LGMT - EKBI
TOM2472    EGCC - LBBG
49D090  OKOLT         2015/08/06 15:38:33   (Let L-200A Morava, OK-OLT, 170613, Blue Sky Service, s.r.o.)
49D109  OKFOX         2015/08/06 15:16:49   (Cessna 152, OK-FOX, 15283865, Flying Academy s.r.o.)
3E8372                       2015/08/07 09:52:31
498458  HANDY22     2015/08/07 11:18:33    (PZL W-3A Sokol, 0715, Czech Air Force)
6DB7ED                     2015/08/07 12:04:02
CYYZGUY
40" LED Monitor
40" LED Monitor
flygfantast
Thanks Alan
4AB4B9 SE-MEY populated, but not 4AB529 SE-MII, hex correct in d/b?
Niklas
Cable: Ecoflex-10 (10m+1m)
M
WZZ1006   EVRA   ENZV
NTJ1554   ESSA   ESNG
NTJ2447   ESNX   ESSA   via ESNO
NTJ2448   ESSA   ESNX   via ESNO
Miscode (allocated 4AB533):
39BEB3 / SE-MIS / DA42 / Diamond DA 42 NG Twin Star / Arctic Road / 42N158 / (ex F-HPVT)
