1 Member and 60 Guests are viewing this topic.
CarlosAbreu
#20626
29-06-2020 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
Morning Terry, thanks again
yang
Mode-s: 71F880
Serial: 19-001
Type: A330-200MRTT
Country: South Korea
Operator: RoKAF
Afternoon Terry, thanks again
SkyPi
#20632
ADFF0B is in the database as T-38C 64-13206. Supposedly confirmed at Williams, but this appears to be an error or miscode.
ADFF0B is a T-6A Texan II, belonging to 455th FTS which is Pensacola based and uses JEDI callsign. Hex sequence would suggest 95-3009, but unconfirmed as yet.
Edit: FWIW, 64-13206 is a T-38A.
CarlosAbreu
30-06-2020 Updated file in attach.
Carlos
Hi Sky Pi
Mil mode-s gives the same information.  It looks likely that the T6 is correct and the T38 is a miscode
Thanks for the info
#20635
Many thanks Terry
For info, the L8's were part of Airnav's first attempt to use the c/n from the FAA data to advise the Aircraft type ICAO code for aircraft not in the database and as can be seen some times it works and some times it didnt.  The second attempt worked a lot better and populated automatically good data into the database with better accuracy
Unfortunately as there are errors in the FAA data it also imported some bad stuff in as well which is not so easy or quick to weed out
X
Unknown Romanian
* 4A4382        2020/07/01 08:56:06
X
Nothing on it X without a registration
SkyPi
Quote from: Runway 31 on June 30, 2020, 08:31:45 PM
Hi Sky Pi
Thanks for the info
I'm one of the LMMS editors.  :)
