0 Members and 51 Guests are viewing this topic.
X
#21015
A Maltese unknown hex and I assume a biz jet from the altitudes
* 4D211F        2020/09/09 20:43:53
4D2103 9H-JOY was around at the time departing VKO so it might be a badly corrupted signal as the altitudes are very similar.
X
X,
Courtesy of Blackswan :
4D211F : 9H-GVA  GL5T c/n 9458
X
X/Ian
A bit of caution with that tie up GL5T 9H-GVA became N499WR in 2017 and is still current on the FAA list
Alan/X,
Just going by what it states as under their 'deliveries and changes' section !
'The Open Sky Aircraft Database' also gives the same information : 9H-GVA c/n 9458.
#21021
Have a look at the FAA https://registry.faa.gov/AircraftInquiry/NNum_Results.aspx?nNumberTxt=499wr
Also the Maltese register as of 4th September where you will not find it https://www.transport.gov.mt/Query-Registration-4-Sep-2020.pdf-f5387
CarlosAbreu
10-09-2020 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
X
Alan/Ian
I will just put 9H-GVA aside and put it down as a probable corrupt signal from 9H-JOY. I did not see it so I am not too concerned.
X
Alan/X
I seldom bother with this forum now, so it doesn't really concern me either ! Just thought it might have been of some help !
No worries Ian, thanks for trying
ffa1978
Quote from: Runway 31 on September 09, 2020, 03:24:37 PM
X
42440A VQ-BYB routed LEMG-EDDM as SBI9992 on its delivery out of the factory 18th June 2017 and as far as I can see the hex code was used until 21st September 2019 last noted operating SBI5044 UFA-Novosibrik.   It may well be that it is now miscoded 42400A but I cannot get any confirmation.  I raised a query on mode-s some time ago but received no replies
I last seen 42440a 22 september 2019.42400a -today.It my opinion 42440a -miscode for 42400a
Thanks for confirming ffa
