0 Members and 100 Guests are viewing this topic.
X
* 4025AC  GBMFG                                                          2020/09/15 10:42:18
This is or was Dornier DO27A-1 G-BMFG c/n 342
X
X
#21047
It was photographed at Orlovka near Tver, Russia in 2018 still as G-BMFG and might be kept in flying condition as a historic aircraft with G-BMFG still painted on. Owned by Vadim Drozdov and I can only find one other Russian one RA-2774G (ex OO-LMH, OO-LMH)but it is not this one
X
Hi X, I picked it up on the network this morning.  G-INFO has it as de-registered as transferred to Russia 19 July 2018 and is c/n 343 ex Portuguese Air Force
So while the transponder gives the details of the previous owner it is not G-BMFG and as far as I am aware should be registered RA-*****   Between 9/2/2018 and 19/7/2018 it was registered to Vadim Drozdov, Khabarovsk, Russia befire being de-registered on 19th Jult 2018
mikek
I bit of a confusing USAF T-1A dilemma.
90-0412 was seen (along with another 13 T-1s, but its code not completely tied up. But it looks like from the codes that are good, that ADFC61 is 90-0412 as it is the only one not matched up. It doesn't fit the sequence (but none of them around those serials seem to) but also shows as correct on a number of other websites.
Mike
Hi Mike
90-0400 is in the database under its registration it used while test flying after upgrade work in 2018, N412FV.  My d/b, planefinder, mil mode-s etc show it as ADFC61.   I have noted the hex on http://www.ads-b.nl/ as 90-0412 using call sign CONGO15 and other CONGO flight ID's so am happy to assign it to 90-0412.  Wonder then what hex 90-0400 is using.  I cant get into the FAA lising just now to see if N412FV is still on it.
CarlosAbreu
15-09-2020 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
X
#21052
new Russian hex with reg
* 141EA7  RA07847                                                        2020/09/16 08:04:26
Flew at over 200knots at 13000ft probably a prop like a new Piper/Cessna type. Came from NE of Moscow and flew south before disappearing. Can find nothing so far.
X
X
Not so sure about this 'UK' hex but nothing else similar around at the time and very few squits
* 42C592        2020/09/16 11:58:18
X
X
Nothing found on 141EA7 RA-07846 and nothing on your miscode
X
#21058
It might be just be wrong button pressed, but it is RA-07847 NOT RA-07846 (which is known and in DB as a TBM9)
X
Thanks Ian, I guess it has been  kept on by the contractors for some reason, its still in the d/b as such
