0 Members and 20 Guests are viewing this topic.
Hi jdsd
N707CK is already in the database as a B744 c/n 26395/922
Can you have a look at your aircraft table and see how many rows you have, todays download should give you 472054 rows
Thanks X, changed to Aeroflot, let me know if thats incorrect first time you see it
jdsd
Hi Alan
I Have 234521 rows loaded in 810mls
jdsd
#21813
I thought that would be the case.  You have more than one instance of RB on your computer and the database download it going to the wrong one
You can have a look in your computer and move the Navdata.db file to the correct instance of the software replacing the one already there
Alteratively I would suggest that you delete all instances of the software including looking at Windows for all Airnav folders left behind and manually deleting them.  Once done reinstall the software making sure you install to somewhere like c:\Airnav making sure you dont install within program files
jdsd
Not the best with computers how do I do that ??? please in simple terms
jdsd
Oh dear, that doesnt make things easy
jdsd
I have found  Navdata.db3 if that helps
jdsd
You should have 2 of them, in its properties what date is the one you have found
jdsd
Hi Alan
I have deleted everything just trying to locate version 6.01 without much luck
jdsd
CarlosAbreu
07-02-2021 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
jdsd
Morning Alan
I have re installed everything again(3 times) but still the same. The date in properties for
DB3 shows modified 27/10/2015
jdsd
That is stil lthe old one you are finding.
What version of Windows are you using
jdsd
Hi Alan
Windows 10 its a brand new computer
jdsd
OK uninstall the software, once done let me know
