0 Members and 16 Guests are viewing this topic.
Once uninstalled, look at your C:\ Drive do you see any folders marked Airnav or Airnav systems, if so manuallly delete the folder/s
Find program files, click on it look for any folders Airnav/Airnav systems
Find program files (x86) click on it and again look for any folders Airnav/Airnav systems and again delete manually
Let me know when you have done that  and if you found Airnav folders
jdsd
Hi Alan
All sorted 472103 in Database explorer
But still some old stuff needs to be deleted CP- B733's one was broken up in 2013,
plus Mode S  that shown various and GND
Just a pity I cannot tidy up the Database manually
Thank you very much for all your help
jdsd
The BOV b733 fleets has been trimmed down to show current only
Unfortuantely there are plenty of aircraft flying around using the same hex codes and there are lots of ground stations that show.  If they were not in the database they would only show as unknown as removing them will not stop them showing
You could trim it manually but unfortunately each time you updated the database they would be downloaded from the server.
As I stated previously the database is purely intended to populate the information associated with hex codes picked up and is not intended for any other purpose
jdsd
CarlosAbreu
08-02-2021 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
SkyPi
AE00A5   70-1557   T38   T-38C Talon   T6247
ffa1978
Quote from: X on February 01, 2021, 10:49:31 AM
Alan/ffa
A mystery A23456 'N241GK' has just landed at Kubinka from Balashov (a large An26 base with a couple of An-74's) so obviously a miscoding Russian Mil. It cruised at 10,000ft but at 500knots so sounds more like a jet. 26850 was c/s but I do not know if a RF-26850 exists.
X
many aircraft (about 17) with this hexcode (not usa code :) )from UZGA .All it is a Russian Air Force  Let L410-UVPE3 Turbolet based on Balashov.One of this i seen on Vostochiy.RF-67360 .New aircraft
Thanks SkyPi, got your post on mode-s
Noted ffa, thanks for the info
CarlosAbreu
09-02-2021 Updated file in attach.
Note: I changed in my database all company name of TAP Express aircrafts because they are not from TAP Air Portugal, they belong to subsidiary PGA Portugália Airlines (Embraer 190/195 fleet) and White Airways (AT76 fleet). TAP Express is only a commercial title due to agreements.
Carlos
No problem Carlos.  The White aircraft are in the database as White/TAP Exress already and all flights are flown using TAP callsigns.
jdsd
Morning Alan
Please can you add
E3EE09   2-NAPA   Hawker 800XP  c/n 258779 owner unkwn
jdsd
#21839
Thanks Terry
I note that 2-NAPA is showing VLZ94A as its flight ID which makes it Volare Aviation
https://www.radarbox.com/flight/VLZ94A
