0 Members and 27 Guests are viewing this topic.
mikek
I've been looking at some of the codes listed with late AE61xx into early AE62xx
At present they are a mix of USAF C-130J and US Army H-60M.
This is what I have at the moment:
AE61FA   in as 18-20982, callsign 175877 so should be AC-130J 17-5877
AE61FB   in as 18-20983, callsign Hydra11 around Eglin AFB, FL
AE61FC   18-5879 callsign king so looks correct
AE61FE   18-5882 looks correct based on altitudes etc
AE6201   18-5886 looks correct based on altitudes etc
AE6204   in as 18-20992, callsigns king and 175892 and seen as a C-130 so should be HC-130J 17-5892
AE6205   in as 18-20993, callsigns RCH and E55893 and seen as a C-130 so should be C-130J 15-5893
AE6206   in as 18-20994, callsigns King and 165895 and seen as a C-130 so should be HC-130J 16-5895
AE6215 was only picked up fleetingly, but at altitudes more likely to be a C-130 than H-60
Of course there are quite a few I haven't picked up in between in that range, but I suspect they all tie in together as a block of C-130s. How sure are the H-60s in that range?
To me either the H-60s are incorrect, or the block has been allocated to both the USAF and US Army?
Mike
#23057
Mike
As far as I am aware the real users of the codes are the H60's but the Herc are also using the same hex codes in this block.  Has been noted for some time, see https://www.live-military-mode-s.eu/
The H60's were using the codes first and then the Herc's came along
CarlosAbreu
06-08-2021 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
Michel
Alan,
AFR205 ZBAA-RKSI-LFPG
CND493 EHAM-LGMT
CND745 EHAM-LTFE
EJU74CD EHAM-LIML
EJU7994 LGSR-EHAM
EJU86DF EHAM-LEPA
EXS15B EGNT-LCPH
EXS20W EGNM-LGSK
FIA618 EGGW-LUKK
FDX34 KIND-EGSS-EDDF
LOT29 EPWA-KMIA
NAX3616 EKCH-LPPT
RYR5576 EGNV-LGKR
TOM2K EGCC-LCLK
TOM4CE EGNT-LCLK
TOM9WA LGRP-EGNT
TRA2583 EHAM-GMTA
TRA5C LIBD-EHAM
TRA51F EHAM-LICC
TRA793P EHAM-LGPZ
VLG59UN EHAM-LEBL
Michel
CarlosAbreu
#23063
07-08-2021 Updated file in attach.
Carlos
Thanks Terry, noted it when it came over me from Keflavik earlier, guess its not taking up its new registration while operating for Amerijet
Michel
Alan,
ABB572 ZSHC-UNKL-EBBR
AFR4018 LFPG-EDDH
CND612 LGRP-EHAM
CND712 LGKO-EHAM
CXI9067 EDDG-GCLP
DLH967 EGNT-EDDF
DTR6061 LEPA-EKBI
DTR6071 LEMG-EKBI
DTR8652 EKBI-LPFR
EDW300 LSZH-BIKF
EJU3654 ESSA-LEMG
EJU48BA LEMG-EKCH
EJU49UC EDDB-EHAM
EJU7900 EHAM-LFMN
EJU7937 EHAM-LGSA
EJU7962 LEPA-EHAM
EJU7993 EHAM-LGSR
EXS63WY LGMT-EGCC
EXS94UW LDDU-EGNM
EZY32KT LGKO-EGSS
EZY73GZ EGCC-LGAV
EZY81YJ LGAV-EGCC
EY92MZ EHAM-EGGW
GDE639 EKYT-LEPA
IBE34WR LEMD-ENGM
IBK3511 EGKK-EKCH
KLM1305 EHAM-LFBO
KLM27L EHAM-LEIB
MEA199 OLBA-EHAM
MEA200 EHAM-OLBA
NAX5071 EKCH-LEMG
NOS6956 BIKF-LIPX
QTR8812 OTHH-EGCC
QTR8813 EGCC-OTHH
RYR2900 EGNM-LGSA
SWR73B LSZH-EHAM
TFL124 LGTS-LGKR-EHAM
TFL133 EHAM-LGKO
TFL2LE LGPZ-EHAM
TFL286 LGRP-EHAM
TFL6WY EHAM-LGIR
THY3HD LTFJ-EGSS
THY3MA LTFE-EHAM
TOM99C EGNT-LCLK
TRA2W EHAM-LEPA
TRA21N EHAM-LIRP
TRA30J EHRD-LDSP
TRA433N EHRD-LIRZ
TRA6258 LDSP-EHRD
TRA659Q LGKR-EHAM
TRA916A LIEO-EHAM
TRA98A LGSA-EHAM
UAE214 KMIA-OMDB
UAE9915 OMDB-EHAM-MMMX
UAL815 EDDF-KIAD
VLG1269 EFHK-LEBL
VLG501A EHAM-LEAL
VLG685H LEBL-ENBR
VLG791Z LEBL-EDDH
VLG85KD GCLP-EKCH
VLG94NQ LEPA-EKBI
Michel
CarlosAbreu
08-09-2021 Updated file in attach.
Carlos
ffa1978
