0 Members and 56 Guests are viewing this topic.
No information on 7A4219 ffa
shark319
Quote from: Runway 31 on August 05, 2021, 11:16:01 AM
Thanks Günter
Have got M-ABLU but have not noted T7-ALX yet
the T7-ALX is still in the Aero-Dienst maintenance facility, registration ist painted on aircraft.
Günter
Thanks Günter will hopefully catch it on departure
ffa1978
Quote from: Runway 31 on August 09, 2021, 07:40:46 AM
10152 Shaanxi Y-9 China Air Force
#23076
Thanks Terry
The information in the database regarding private individuals or otherwise comes from publicly available sources such as G-INFO in the case of G-DONE.  Some countries such a Sweden/The Netherlands do not publish the details of private individuals
I would suggest that the details regarding companies appears to change more often as can be seen from the frequent logo changes.
Anyone, individual/company is free to contact the relevent authoriities and have their details made private as can be seen from the aircraft marked BLOCKED on RB24.  The FAA even have a system available whereby individuals/companies can apply for a "tactical code" for their aircraft to ensure anonimity.  This coding I believe changes every 6 weeks or so.
The RB network is an open network available to anyone viewing RB.  The Airnav network as seen on V6 is a closed/private network not available to the general public with an encrypted database making it limited to users with a receiver and are feeding the network and therefore escapes the same blocking
You are free to use your own database as you see fit and as it is a private database I would think you will be outwith the scope of data legistlation so no need to fret.  Any compliance requirements rests with Airnav Systems and I have no knowledge of their systems in place to ensure compliance and suggest that you contact them in this regard if you are concerned
CarlosAbreu
#23077
09-08-2021 Updated file in attach.
Carlos
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
mikek
AE4D5B, MH-60S, 168581
Mike
X
AB2BA5 is miscoding old hex of N819JT Cessna 182 and is now RA-67212 as per c/s
X
ffa1978
I dont have any details ffa
