0 Members and 39 Guests are viewing this topic.
Thanks again Niklas.
47C552,LN-YTP,DY531/2015,Aerospool WT-9 Dynamic RG
X
#2851
ABY736   OMSJ-HKJK                A6-AOI     A320  Air Arabia           2015/10/05 19:51:06
ABY737   HKJK-OMSJ                A6-AOI     A320  Air Arabia           20115/10/06
SAW782                                   UR-CNU     A320  Dart Airlines/Cha... 2015/10/05 17:40:31
And more OEJN Haj flights numbers
SVA5136                  TF-AAC     B744  Air Atlanta Icela... 2015/10/05 11:54:41
SVA5124                  TF-AAD     B744  Air Atlanta Icela... 2015/10/05 10:56:21
SVA3811                  TF-AAD     B744  Air Atlanta Icela... 2015/10/05 21:11:32
KNE8532                  TS-INF     A320  Nouvelair Tunisie... 2015/10/05 22:16:41
KNE8552                  TS-INR     A320  Nouvelair Tunisie    2015/10/05 21:04:34
AIC5128                  VT-ALK     B77W  Air India            2015/10/05 07:20:51
AIC5132                  VT-ALK     B77W  Air India            2015/10/05 23:15:12
AIC5222                  VT-ALN     B77W  Air India            2015/10/05 05:14:08
X
X
Do not know why this one came up blank!
DHX134 OMDB-OBBI  A9C-DHC    B752  SNAS Aviation/DHL... 2015/10/06 11:13:20
Plus
DHX230 OERK-OMDB              A9C-DHC    B752  SNAS Aviation/DHL... 2015/10/06 09:02:14
UPS270  OMDB-EDDK-KSTL?   N280UP     MD11  UPS Airlines         2015/10/06 12:50:52
And probably Haj charters to/from Dhaka to JED
BBC4029                  S2-AFO     B77W  Biman Bangladesh ... 2015/10/06 08:49:35
BBC6029                  S2-AHM     B77W  Biman Bangladesh ... 2015/10/06 14:32:00
X
Thanks again X, nothing against it in the d/b
Afternoon Alan,
Can you do the necessary at your end :
A9A3C6   N720CH BD700-1A10 c/n 9100. Details are correct but the accompanying photo shown is for the previous incumbent of that registration namely B737 c/n 29866.
Its done Ian, remember and delete the photos if you haven't already done so.
Aerotower
I don't no if you can help, but I have catch a plane with the military flag on mode-s (E4018C), but the plane is civil (Embraer Legacy 500). It is possible that the flag's document is wrong?
And I don't now if you already have join this mode-s to the database (E400E5 - Super Tucano - BAF)
Best regards
Manuel,
E4018C hs been used previously on PT-TCJ which is an Embraer test registration  Unfortunately the hex code may not be allocated to the registration the next time it is used.  The registration had been used at least 4 times before.  It is possible that the flag has been wrongly allocated,
E400E5 is in a batch of Super Tucano serials but I am unaware that it has been tied up
Aerotower
I now that, i'm in São José dos Campos with view to the runway and on the approch line.
I have catch now the PR-LIC mode-s E401CA - Legacy 500, maybe it´s an Embraer test registration.
I have the video too - https://youtu.be/LHlA9h5HtEI
Manuel,
E401CA,PR-LIC,55000029,Embraer EMB 550 Legacy 500,Embraer
Checked the Brazilian register PR-TCJ is showing as Registro não encontrado
jim_stockwell
Hi Alan
been out of the loop for a few days so have not updated the database and therefore have a couple of queries from today which you may already have resolved.
Hex 4CA529 was not not populating
and a funny one,
Hex 49D137 which the database has as a Robinson R44 OK-BLA, but I am sure it was an EMB 135 when it passed me! FR24 had it as OK-AEG which is a 135.
Airframes has both BLA and AEG with the same Hex code
Over to you
Jim
diddyboy
Hi Alan
A few more ground Transmissions from the Sandpit
896ED0  AIR24                                                          2015/10/07 12:23:42
   896ED5  AIR25                                                          2015/10/07 10:35:53
   896ED7  OES2                                                           2015/10/07 11:11:30
* 896EDA  PRO02                                                          2015/10/07 10:03:43
Neil
#2863
Hi Jim,
4CA529,EI-FHS,39021/4371,Boeing 737-8JP,Norwegian Air Shuttle
49D137,OK-AEG,14501111,Embraer ERJ 135BJ Legacy 600,ABS Jets  I could have sworn it was in the d/b.  The R44 is now OM-OIL.
