0 Members and 43 Guests are viewing this topic.
shouriken
QuoteThanks Liviu, I will advise Airnav, it must be a server issue again, this has been noted 2 or 3 times now.
Thank you. I've edited my aircraft table.
Liviu
A.net JetPhotos.Net
RadarBox
Michel
Alan,
SAS4741 ENGM-EBBR
Michel.
AoD
Hi Alan
GWI6905   LBSF - EDDH
MNB264   OTHH - LTBA - EHAM
THY4BT   LTBA - EDDH
THY4YW   LTBA - EHRD
THY5ZR   LTBA - EDDL
THY9HZ   EGLL - LTBA
company update:
49D10F, OK-FTR, CTR Flight Services
M
SAS2037   ESNU   ESSA
SAS7503   ENVA   LCLK
SAS7504   LCLK   ENVA
FIN559   EFIV   EFHK   via EFKT
ADR7175   EETN   EBBR
ADR7176   EBBR   EETN
ADR7177   EETN   EBBR
ADR7178   EBBR   EETN
ADR7311   EETN   UKBB
ADR7312   UKBB   EETN
ADR7141   EETN   EKCH
ADR7142   EKCH   EETN
ADR7143   EETN   EKCH
ADR7144   EKCH   EETN
ADR7145   EETN   EKCH
ADR7146   EKCH   EETN
Many thanks M, glad to see the void is being filled quickly after the demise of Estonian.
Afternoon Alan,
Just flown over with full ADSB and clearly visible :
D-AVVA A320-271N c/n 6286 and flight ID of AIB97VA. It is in the d/b.
Any idea if this is on delivery to someone or if it is a neos Airbus demonstrator ?
Good Evening Alan,
unknowns from Monday:
MILs Germany:
  3E8C93  PACK32                                                         2015/11/09 13:29:29
   3E94FE  VADER31                                                        2015/11/09 08:37:38
   3E94FE  PACK31                                                         2015/11/09 13:25:19
   3E9613  RAGE                                                           2015/11/09 09:33:47
   3E9613  RAGE                                                           2015/11/09 15:17:45
   3EA610  IRON1                                                          2015/11/09 17:01:07
* 3EADA3  LION                                                           2015/11/09 15:55:02
   3F4A0F  IRON2                                                          2015/11/09 17:00:29
* 3F4F1B  BU02                                                           2015/11/09 13:53:14
* 3F4F1B  BU02                                                           2015/11/09 14:58:17
   3F5494  GAFK10                                                         2015/11/09 08:15:45
* 3F604D        2015/11/09 17:32:20
   3F64DF  HG01                                                           2015/11/09 07:23:02
   3F64DF  HG01B                                                          2015/11/09 11:16:30
* 3F6618  GUNNER2                                                        2015/11/09 14:40:13
   3F71EF  APEX                                                           2015/11/09 10:36:59
   3F71EF  APEX                                                           2015/11/09 11:31:05
* 3F72F9  OSBORN1                                                        2015/11/09 16:17:58
* 3F7832  GAF442                                                         2015/11/09 07:47:38
   3F7C7C  PACK11                                                         2015/11/09 07:10:59
   3F8149  ANVIL1                                                         2015/11/09 11:18:03
   3F8A0F        2015/11/09 07:13:41
   3F8A0F  HG01B                                                          2015/11/09 11:15:08
   3F909B  GUNNER1                                                        2015/11/09 14:20:13
   3FBC3C  GAF292                                                         2015/11/09 08:56:48
   3FBC3C  GAF292                                                         2015/11/09 12:55:01
4008DA was G-TMRA nothing about a new one
4CA999 nothing more
50008A  T7JPS no further information
896156 nothing more
MILs:
AE18AF  DEFAULT
AE1942  DEFAULT
Regards Ingo
#3309
D-AVVA is the current Airbus Test Reg of second NEO Test Airframe. I don't think, that this one will be delivered to a customer.
http://www.flightradar24.com/data/airplanes/d-avva/#7f052e3 suggests, that it was on a test flight.
X
New Sri Lankan, I would suggest possibly 4R-ALP if in sequence
* 770590        2015/11/10 20:20:01
X
Cheers Ingo.
Thanks for that. Good one for me to get.
Ian, I agree with Ingo on the Airbus.
Hi Ingo,
Mil tac added and nothing on your others
X
770590,4R-ALP,1669,Airbus A330-343,SriLankan Airlines
