0 Members and 93 Guests are viewing this topic.
Michel
#3330
Alan/Andrew,
AFR132G LFPG-ENGM
AFR147E LFPG-EDDH
CFG3EA GCLP-EDDH
IBK2875 EDDB-EGKK
PGT72Q EHAM-LTFJ iso LFTJ-EDDF
SAS2578 EBBR-ESGG
TUI7K GCLP-EDDH iso GCLP-EDDV
VKG2754 GCLP-ESMS iso HEGN-ESMS
Michel.
orkney
Hello Michel
That is that ones done.
Thank you
Andrew
X
Andrew/Alan
This is a Bell Textron B429 C/N 57224 at airshow
* C022E5  CFNFO                                                          2015/11/13 16:06:03
X
orkney
Hello X
That is that one in now.
Andrew
paul tricker
Alan/Andrew
7335AA is EP-MMJ  A310-304   526  Mahan Air
Paul
orkney
Hello Paul
That is it done now.
Thank you
Andrew
Northern Watch
Hi Andrew
One from today that did not populate:
3E9CBD / c/s GAF331 / German Mil Tac code?
Keith
Michel
#3337
Andrew,
AFR142C ESGG-LFPG iso LFPG-LIPZ
AFR664L LFPG-ESGG
BLX590 GCLP-ESSA iso GCLP-ESMS
EWG3K EDDL-EGCC
IBE32ZM EDDH-LEMD
MAS6121 EHAM-OMDW-WMKK iso EHAM-WMKK
SAS1597 ESSA-EBBR
SQC7345 EHAM-OMSJ-WSSS
SQC7346 WSSS-OMSJ-EHAM
TFL410 OMDW-LBBG-EHAM iso OMDB-LBBG-EHAM
TFL924 HEGN-EHAM iso HESH-EHAM
TUI2363 GCLP-EFHK
Michel.
orkney
Hello Michel and Keith
That ones are done now.
Thank you again
Andrew
X
Andrew/alan
This I-RAIK is an AW169 due for Dubai Air Wing but may continue to miscode, will let you know
* 31FEF7  IRAIK                                                          2015/11/14 15:12:26
X
x
The hex/code combination is a test combo and has been used a G222, SF260, P68 4 x A139's and the current  A169 c/n 69006
Michel
Alan,
KLM25F EHAM-LIPE
TRA1V LEAL-EHAM
TUI1YP GCFV-EDDH iso GCFV-EDDV
Picked up 78028E B-8226 A330-243 China Eastern for the first time today, but it was listed with ac type B738 iso A332.
Michel.
#3342
Thanks again Michel,
I have no idea how that happens as its in the d/b and on my Navdata as an Airbus A330-243
The TRA is in the d/b already.
X
#3343
I-RAIK is 69006, but not sure if it will change hex as it should, I will let you know
x
