0 Members and 25 Guests are viewing this topic.
#3495
Alan,
New destination for me but verified by the Alicante departures board :
JAF6JM : LEAL-EBAW
Also, AE1BA7 is back on again. This time using flight ID 'NM31'. FL240 and Mode S only.
EDIT: It's just flown over and is a P3 Orion !
It was fine for me until I clicked on it then the registration changed to the link.  I have deleted it now so lets see what happened tomorrow
Cheers Ian, many thanks.  Still no info on AE1BA7.
paul tricker
No idea why X has not picked this up,
896277 is in the d/b as A6-FDB, it should be A6-FDE. all other details are correct
Paul
AoD
company update:
3CF68E,   D-CURE,   Aero-Dienst
4CA176,   EI-LEO,   Airlink Airways
49D05A,   OK-HCB,   Travel Service
4AB195,   SE-LLU,   Waltair Europe
49D0C6,   OK-SLN,   ABS Jets
CYYZGUY
#3501
40" LED Monitor
40" LED Monitor
X
* 4B18A5        2015/11/29 21:06:08
* 734064        2015/11/29 17:20:23
* 734064        2015/11/29 18:17:06
734064 decodes to EP-PCD and was reported by me back in 2011, so whatever it is, its still around and flies up to 10000ft, possibly an Iranian oil rig supply chopper out of Kish.
X
X
#3505
* 12F35C        2015/11/30 06:43:10
* 896373        2015/11/30 01:53:47
* AB5093        2015/11/30 09:11:07
The UAE one was departing and noted between 6000ft and 19000ft.
The US was at low level so probably miscoding its old hex of N828WM which was exported to UAE 2013 and is a AMERICAN CHAMPION AIRCRAFT Model 8KCAB  c/n 1077-2008 Operator/owner unknown
X
Morning Alan,
JAF2DM : LEAL-EBBR
EVE1123 : LEAL-GCTS-LEMG
(Bit of a scenic route to LEMG but it's confirmed by the LEAL departures board).
X
4B18A5 decodes to HB-JIR not allocated and as far as I can see never has previously
734064 decodes as you state to EP-PCD, searched the internet, Rotorspot and Helis.com and can find no information
896373 was used previously by H25B A6-ELC so look like it has been re-allocated and is unknown to me
AB5093,2230,1077-2008,American Champion 8KCAB Super Decathlon,United Arab Emirates - Air Force (Miscode hex of N828WM)
X
Thanks, however I have A6-ELC Hawker 850XP 258781 as 896161 not 896373?
   896161                           A6-ELC     H25B  Prestige Jet         2015/02/08 12:36:56
   896161                           A6-ELC     H25B  Prestige Jet         2015/02/08 13:00:06
PS No idea how I missed the flyDubai B738 issue Paul mentioned...probably because I saw them in 2009, well before I joined the forum!
X
