0 Members and 71 Guests are viewing this topic.
Hello Alan, Unknowns from Monday :
416131 nothing more
* 43E8C6  MSFOZ
461FA3 nothing more
47839E nothing more
4B16B1 nothing more
4D01CA nothing more
7583AB  PAL5007 http://xfw-spotter.blogspot.de/2015/04/a321-231sl-philippines-airlines-d-avxd.html was added after it was in my range I guess
MILs:
* 3E9543  GAF120                                                         2015/04/27 08:39:31
* 3F4997  SMASH1                                                         2015/04/27 14:03:44
* 3F4997  PACK1                                                          2015/04/27 18:56:25
   3F4FBE  APEX1                                                          2015/04/27 08:29:50
   3F4FBE  BU01                                                           2015/04/27 19:16:12
* 3F51D6        2015/04/27 07:28:13
   3F7069  SMASH                                                          2015/04/27 19:41:15
   3F730D  SHOCK1                                                         2015/04/27 13:49:09
   3F730D        2015/04/27 19:18:53
* 3F77A7  KNIGHT                                                         2015/04/27 18:12:08
   3F78D7  SHOCK2                                                         2015/04/27 13:58:27
   3F78D7  SHOCK1                                                         2015/04/27 19:03:42
* 3FB43B        2015/04/27 10:26:52
* 3FB43B  GAF910                                                         2015/04/27 14:54:20
Regards Ingo
Unknowns from Sunday:
3C4968  was D-ABKH nothing about a new one
400ADC was G-GMAC written off in 2004
 4844CE  KLM1978  LHBP-EHAM hex matches PH-DFC was last a TOBA. Therefore a decoding error I guess.
780C54 nothing more
 A1BEEE  N211TM http://registry.faa.gov/aircraftinquiry/NNum_Results.aspx?omni=Home-N-Number&nNumberTxt=N211TM
Regards Ingo
Ingo,
Sunday
A1BEEE,N211TM,3572,Cirrus SR22,Aircraft Guaranty Corp Trustee
Nothing on the others
Ingo,
Monday
43E8C6,M-SFOZ,121,Dassault Falcon 2000,Executive Aircraft Services
Nothing on the others, mil tac added
Michel
Alan,
AFR652E EKBI-LFPG
TRA896 LTBS-EHRD iso LTBS-EHRD-EHEH
Michel.
shouriken
4A0835 - YR-BAU - B734 - Boeing 737-4Y0 - 26066/2301 - Blue Air, ex UR-GAX, N606AN
Liviu
A.net JetPhotos.Net
RadarBox
Hi Alan, Unknowns from Tuesday :
3C659F nothing more
4240B4 decodes VP-BLF but only airframe I could find was scrapped a couple of years ago
4801F1 nothing more
484468 was PH-3U2 no active airframe with this hex/reg found
4B3904 nothing more
4CC2C1 nothing more
9803C8 no country allocation
MILs :
* 3E859D  GAF103   BIKF-EDDK                                             2015/04/28 06:57:54
* 3EA1F8  GAF926                                                         2015/04/28 07:08:31
* 3EA1F8  GAF926                                                         2015/04/28 09:29:20
* 3EA1F8        2015/04/28 11:30:16
* 3EA1F8  TA64                                                           2015/04/28 14:15:19
* 3F598D  AXEMAN                                                         2015/04/28 08:14:56
* 3F7420  ATTACK3                                                        2015/04/28 08:25:06
* 3F7420        2015/04/28 09:18:00
* 3F9A75        2015/04/28 16:23:07
Regards Ingo
Thanks Ingo,
Nothing found on your unknowns and the mil tac added
Afternoon Alan,
D-ABAG B737-86J c/n 30879 is in d/b as wfu/stored ex Air Berlin. It's back in service with them and just flown over on the LEJR-LEPA route.
Thanks for that Ian, had been in storage at Budapest
Michel
Alan,
AFR145M ESGG-LFPG
Michel.
diddyboy
Hi Alan
One not populating from JNB after arrival last night.
* A4D6A3        2015/04/29 19:20:36
Neil
