0 Members and 71 Guests are viewing this topic.
M
WZZ144   EVRA   ENZV
WZZ59R   ENZV   EVRA
PIA712   KJFK   OPLA
PIA790   CYYZ   OPLA
GEC8398   EDDF   RKSI   via ZBAA
SE-MAY (4AB439) is miscoding in one transponder:
4AB479 SE-MAY ATP
Have been trying to work that one out for ages Neil.  It decodes to N4101H which was allocated to a Mooney destroyed in 2000.  It is now a Cessna test registration and could be anything miscoding it.
X
Unknown Jordanian at 16000 for 8 minutes but only 6 messages
* 740739        2015/04/30 00:08:57
X
Comes up as JY-AYY with nothing else found X
X
740739 must have been JY-AYQ either double coding or getting mixed up at a distance, explains only six messages
740731                           JY-AYQ     A320  Royal Jordanian A... 2015/04/30 00:08:24
X
Looks like a corrupt packet from that one X
X
Well you got FDB7415 in advance so it populated but off course it is going ever upwards with todays new f/n's
FDB7417    OMDB-OEJN             A6-FDD     B738  flydubai             2015/04/30 12:00:52
FDB7418    OEJN-OMDB
X
Cheers X, added another couple in as well
Hi Alan, Unknowns from Wednesday :
1406A4 nothing more
3C864C nothing more
3FEEE0  DMDBS http://www.flugschulemd.de/index.php/downloads.html
400CDD was G-F IP B737 nothing about a new one
4AC957 nothing more
A5301B decodes N433UX which isn't assigned or reserved by FAA
A79027  N587CM http://registry.faa.gov/aircraftinquiry/NNum_Results.aspx?NNumbertxt=N587CM
C9A081 no country allocation
MILs :
* 3EA29E  GAF611                                                         2015/04/29 07:03:25
* 3EA29E  GAF611                                                         2015/04/29 10:06:11
* 3EA29E        2015/04/29 14:13:02
* 3EA29E  TA60                                                           2015/04/29 16:05:24
* 3EA29E  TA60                                                           2015/04/29 18:12:17
   3F9A75        2015/04/29 07:22:24  <<you haven't added this one yesterday.
Regards Ingo
Xon
#385
Quote from: Runway 31 on April 24, 2015, 04:58:00 PM
Thanks again Xon c/n DY065/2004
Thx
48A425 SP-KBF SR22 c/n probably 2568 (ex N545SR)
Thanks again Xon, it looks a likely candidate
Evening Ingo,
The 2 knows and the mil tac added, sorry about the one from yesterday.  Nothing on your unknowns.
Evening Alan,
I can confirm that VLG21VG is LEMG-LEBL.
