0 Members and 21 Guests are viewing this topic.
QuoteI have downloaded today and photo links, photographer details are present us usual.  However photos not downloading, I will advise Airnav that there is an issue
Okay. Also let them know that individual update of aircraft records is not working either.
oliver14
AE1796 "Custer" callsign, a new F15 just popped up on the box.
Have noted that myself Chris and have already advised.
falcon_nl
Thanks Alan for both new ones
CYYZGUY
WJA2699
No Routing
http://flightaware.com/live/flight/WJA2699
WJA4267
No Routing
http://flightaware.com/live/flight/WJA4267
Also, I see the Travel Service is here, Mode-S 49D276, Flight ID TVS501P, REG: OK-TVU   Not too sure why the "P" at the end however...
Jason
40" LED Monitor
40" LED Monitor
Thanks Jason.
I would think that the P indicates a positioning flight probably coming from Prague on its arrival on lease.
Morning Alan,
EVE1121 : LEAL-LEVX
EVE1205 : LEVX-LEMG
EVE1119 : LEAL-LEST
EVE1120 : LEST-LEAL
EVE1206 : LEMG-LEVX
EVE1122 : LEVX-LEAL
This outfit appear to have started a lot of new routes.
IBK9JY : EDDH-LEAL
jacobite
Hi Alan, I need your help please. I have just upgraded to windows 10 and I am unable to get ANRB to work. I have tried to install the drivers (64) but they will not work. I have already updated the software to the latest version, what have I done wrong. Your help would be much appreciated.
Ian,
Did you follow the advice on the Windows 8 sticky.  Usually no problems doing an upgrade from 7 or 8 to 10, straight forward and works straight away without needing to do anything.
Cheers Ian (EK01),
Another lot you will soon be sick and tired picking up.
jacobite
#3716
Quote from: Runway 31 on December 16, 2015, 10:45:58 AM
Ian,
No Alan, I just downloaded the driver. I have found the sticky and I did follow the instructions, but the drivers I have are showing that they are corrupt or have been tampered with.
Its at the top of the page Ian
If you experience any issues with Windows 8 Drivers please try the following when trying to install them.
Windows 8:
In the meanwhile users have managed to get it to work using the below tips:
1. From the Metro Start Screen, open Settings (move your mouse to the bottom-right-corner of the screen and wait for the pop-out bar to appear, then click the Gear icon).
2. Click 'Change PC Settings'.
3. Click 'General'.
4. Scroll down, and click 'Restart now' under 'Advanced startup'.
5. Click 'Troubleshoot'.
6. Click 'Advanced Options'
7. Click 'Startup Settings'
8. Click Restart
9. When Win8 restarts type the number next to \"Disable driver signature enforcement\"
For Windows 8 drivers please download:
http://www.airnavsystems.com/download/anrb/drivers/ANRB-Win8Drivers-v2.08.30.zip
Instructions:
1- Download the file above;
2- Unzip it to a folder on your computer;
3- Disconnect your RadarBox USB cable, wait a few seconds and connect it again;
4- When Windows prompts you to find the proper RadarBox driver browse the folder where you have extracted your drivers to;
If the above Windows prompt box does not appear:
1- Go to Windows Control Panel - Device Manager- USB Controllers - RadarBox - Driver -  Update Driver
2- Point at the relevant folder and install the drivers;
If you are using Windows 8.1, do the following:
3. Scroll down, and click 'update and recovery'
4. Click 'recovery'
5. Click under advanced start up and restart now
6. Click 'Troubleshoot'
8. Click Restart
Instructions:
jacobite
I have tried all I can to install the drivers Alan, all I keep getting is the following message.
Windows encountered a problem installing the driver software for your device.
Windows found driver software for your device but encountered an error while attempting to install it.
The hash for the file is not present in the specified catalogue file. The file is likely corrupt or the victim of tampering.
If you followed the sticky all I can suggest is that you contact support@airnavsystems Ian
