0 Members and 61 Guests are viewing this topic.
Afternoon Alan,
Delivered yesterday to Iberia :
EC-MIL A330-200 c/n 1694. No idea of the hex code.
Cheers Ian,
It is 3450D5 and is an A330-202
Alan,
IBK5536 : LEAL-ESGG
RYR8836 : LIME-GCTS
RYR8837 : GCTS-LIME
VLG1395 : LIMC-LEMG
Fanjet500
Hi all,
Could someone tell me how i get the Embraer 550 Legacy 500 into my Database explorer. What is the offical ICAO aircraft code? How do i get a silhouette? How is it with the Embraer 450? How is the procedure anyway. Do the new aircraft types automatically appear in the database or is it a must to put it into the database? Sorry to ask, but is it also possible to see the ICAO type in the list if an aircraft is received when the type is not in the database?
Thank you for your help.
Rolf
2 Airnav Radarbox installations
2 Antenna switch boxes
1 WiMo GP-1090
1 FLU-SR/Y13
2 ThieCom SkySearcher directional antennas
2 Standard Airnav Radarbox antennas
#3936
Rolf,
The is ICAO code for the Embraer 550 Legacy 500 is E550 and this is in the database and is included in the Navdata.
The Embraer EMB 545 Legacy 450 does not have an ICAO code allocated and it is therefore in the database using the ICAO ZZZZ identifier.
You will find the aircraft codes in the aircraft table in the database along with details of the types covered by the identifier.
The ICAO identifiers don't automatically load into the database, like everything else they require to be manually input onto the server.  The codes are produced in ICAO DOC8643 Aircraft Type Designators http://www.icao.int/publications/DOC8643/Pages/default.aspx which was last updated on 14th April 2015 and when it is published the database is updated to cover any additions/amendments or deletions.
I am not aware of a standard silhouette for the E550 but Rod has produced a photo type silhouette and it is available here on the forum http://www.airnavsystems.com/forum/index.php?topic=1290.msg108329#msg108329
Michel
Alan,
TUI65K GVAC-EDDH iso GVAC-EDDV
Michel
Fanjet500
Alan,
thank you very much for your help. You do a great job here in the forum. I did find the silhouette. In my database explorer is no E550 aircraft listed. How do i find the navdata. Can i add the E550 manually? Do i have to do a navdata update? Where do i find the navdata for an update? Sorry Alan for so many questions.
Thanks Rolf
1 WiMo GP-1090
1 FLU-SR/Y13
lenow
TAP764 LPPT ENCM
In database as lppt lezl
#3940
Rolf,
To allow me to give a complete answer, which version of Radarbox are you using?
CYYZGUY
40" LED Monitor
40" LED Monitor
Thanks Lenow, that one has been in the d/b since 2012, also changed the return TAP763 as well
