0 Members and 15 Guests are viewing this topic.
diddyboy
Hi Alan
Many Thanks
Be advise that it is 5Y-CAU and not 5H-CAU as you have shown above, but still using its old hex of 5H-KMC.
Neil
superspotter
Hello once again from Lagos. After an almost 5 month hiatus, one finds oneself shoved here again!
ZS-HMD an AW139 of Titan helicopters is operating around here but using the hexcode 300000. The Airnav Db has this being misused already by an american and a french aircraft, well now it's a triumvirate :)
regards clive.
Hello Clive, I wondered where you had got to so nice to hear from you.  Added that one to the misused list.
Morning Alan,
JAF869 : LFBO-GMAD and not GMMN-LFPO as shown in d/b.
Also, showing in My Flights is EC-MAE AW109 c/n 11619 of INAER Asset Management. However, the hex given is 3988EC which is a French code so possible re-reg in the offing or an ex INAER France machine using it's old hex. Probably operating out of Muchamiel.
Thanks Ian
3988EC,EC-MAE,11619,AgustaWestland AW109E Power,Inaer (Miscode hex of F-HCHM),
phelpsl
One not in database...
* 43C7D7  ZK560                                                          2016/01/13 14:04:24
...also I believe that the following is a wrong short type code. Should be CL85.
* 503D19  LTC801                   LY-LTY     CRJ2  Charter Jets         2016/01/13 11:28:35
Les
Hi Les
43C7D7,ZK560,M.7711,Boeing Chinook HC6,UK - Air Force
CRJ2 is the correct ICAO code for the Challenger 850 as detailed within http://www.icao.int/publications/DOC8643/Pages/Search.aspx .
superspotter
Good morning from Lagos;
Hexcode 0641CC is 5N-RRS AS350 of the new police Rapid Response Squad, hence the reg. There is also 0641CD that keeps pinging but not tied it up yet.
regards clive.
Morning Clive,
I can find nothing on 5N-RRS other than a photo on the web but have added it into the d/b with what we know.
0641CD should decode to 5N-SOS but I can find nothing on it either.
Many thanks
diddyboy
Hi Alan
Some from Wilson
500000, 5Y-JJZ. Beech 200, c/n BB-1127, Corporate
C058CB, 5Y-CBX, Beech 300, c/n FA-39, Corporate,
AB2219, 5H-AAF, Cessna 208B, c/n 208B-5102, Auric Air Services
A22426, N237SW, EMB-120, c/n 120314, No operator yet but being worked on by Freedom Airlines.
A1A83A, 5Y-MJA, Cessna 208B, c/n 208B-2203, Phoenix Aviation.
Neil
Evening Alan, some unknowns from yesterday:
45B888 nothing more
4D2124 nothing more
ED2F20 no country allocation
MILs:
* 3E8CC7        2016/01/13 13:41:40
   3E8FBA  NITRO1                                                         2016/01/13 09:46:45
* 3EBC3D  HELI143                                                        2016/01/13 13:15:05
   3F4BD2        2016/01/13 09:23:53
   3F4BD2  HG01A                                                          2016/01/13 13:51:32
   3F4E8D  SHOCK31                                                        2016/01/13 08:16:35
   3F4EF9  SHOCK21                                                        2016/01/13 13:03:28
   3F5F18        2016/01/13 12:02:43
* 3F6E2D  GAFM53                                                         2016/01/13 12:05:39
   3F6F5E  NITRO3                                                         2016/01/13 09:51:35
   3F70D6  SHOCK33                                                        2016/01/13 08:24:21
   3F8969  GATOR                                                          2016/01/13 14:07:57
* 3FB7A8  GAF302                                                         2016/01/13 08:56:09
   3FB90F        2016/01/13 09:50:36
   3FB90F        2016/01/13 14:21:17
Regards Ingo
From Tuesday:
3D18B5  DEHPL  I've received this one more than 10 times with this hex / flight id. https://planefinder.net/data/aircraft/D-EHPL from Flugzeugforum.de: Piper Malibu Mirage, Bavaria Flight Service
3DAC4B        2016/01/12 08:57:57
3DAC4B        2016/01/12 10:41:07
D-GLMP no further information
4B9685 was TC-ETE  B752 of various operators. I've found no indication of a new airframe using this reg/hex tie-up.
MILs:
* 3E814C  GAF474                                                         2016/01/12 08:04:37
* 3E886D        2016/01/12 12:04:53
* 3E8FF0  GAF781T                                                        2016/01/12 09:20:51
* 3E8FF0  GAF781T                                                        2016/01/12 12:10:55
* 3E9165  GAF209                                                         2016/01/12 09:13:39
* 3E9165  GAF209                                                         2016/01/12 11:20:52
   3E9324  HG01B                                                          2016/01/12 07:23:26
   3E9324        2016/01/12 11:54:44
   3E96D7  GAF673T                                                        2016/01/12 13:18:38
   3EAF6E  STRIKE2                                                        2016/01/12 14:17:15
   3EAF6E        2016/01/12 15:10:00
   3EAF6E  GHOST3                                                         2016/01/12 19:53:50
   3EAF6E  GHOST2                                                         2016/01/12 20:03:17
* 3F468B        2016/01/12 13:27:31
* 3F5D62  STRIKE1                                                        2016/01/12 14:12:31
* 3F5D62  GHOST1                                                         2016/01/12 19:45:43
   3F5DBA  PANTER                                                         2016/01/12 14:10:55
   3F62AB  BU02T                                                          2016/01/12 09:42:44
   3F62AB  BU02T                                                          2016/01/12 17:20:44
   3F6E32  PACK22                                                         2016/01/12 08:36:47
   3F6E32  CLUB21                                                         2016/01/12 13:33:46
* 3F6F5E        2016/01/12 09:33:45
* 3F6F5E  GHOST3                                                         2016/01/12 19:21:45
   3F7380  GAF358                                                         2016/01/12 15:31:55
* 3F8969  GATOR                                                          2016/01/12 14:17:51
* 3F8A55        2016/01/12 19:24:10
* 3FA9B1  APEX1                                                          2016/01/12 14:19:33
* 3FB90F  STRIKE3                                                        2016/01/12 14:17:56
* 3FB90F        2016/01/12 15:07:15
   3FBBA5  GAFM51                                                         2016/01/12 11:27:42
Regards Ingo
Thanks again Neil, N237SW no longer of FAA register and my d/b has it was Freedom Express Airlines
Many thanks Ingo,
3D18B5,D-EHPL,4636471,Piper PA-46-350P Malibu Mirage
Nothing on the others and hopefully all the mil tac done
