0 Members and 9 Guests are viewing this topic.
It seems, that you got all mils into the db. Hopefully from now on I'll be able to post my unknowns on a daily basis again.
Thanks, Ingo
Thanks Ingo, for your information the Navdata update routine for the Aircraft Table  is defective and will hopefully be fixed soon.  Populate and auto-populate work OK though
Neil,
Regarding C058CB, 5Y-CBX, Beech 300, c/n FA-39, Corporate,  This hex code passed over Aberdeen a short time ago inbound Wick, if its the same one it looks to be returning to Canada.  Was it today you picked it up and what time?
diddyboy
Hi Alan
Picked it up on the 11th initially, but not identified, was seen going ground runs on the 12th and then confirmed on departure on the 13th at 09:15 and haven't picked it up since then.
Also in regards to EMB-120 N237SW, it is still registered as such and in UA colours without titles.
Neil
X
#4129
   3CCD41  IFA1041                                                        2016/01/15 05:56:45
* 4BD140  CAI5385                                                        2016/01/15 06:21:03
   706034        2016/01/15 06:14:55
* AE573C        2016/01/15 06:49:26
I thought the Kuwaiti was spurious but that is 4th time I have picked it up, the German is the fifth time and is in and out of Minhad from heights always on IFA f/n's.
X
Thanks Neil,
It probably was 5Y-CBX that was noted inbound Wick yesterday evening.
The FAA details that N237SW was cancelled from the FAA register 22/12/15 as exported to Kenya.
X
3CCD41 is LJ60 D-CFAN c/n 60-119 c/n which is already in the d/b however just checked my Navdata and it is not showing in their so probably resulting from the continuing aircraft table update issue.  It should populate OK if clicked on when on screen or update if auto-populate used in Mylog.
4BD140 is not allocated in the Turkish system.  However there are a number of CAI aircraft allocated in the 4BD14* range so I would suggest this is a corrupt packet
706034 unknown to me
AE573C unknown to me
Cheers Alan
M
LOT79   EPWA   RJAA
LOT80   RJAA   EPWA
ABW317   EDDF   EFHK
ABW318   EFHK   UUEE
GreekSpy2001
 From Skyliner  Airbus A321     -212     1691          C-FJNX     Air Canada     delivery 15jan16 TLS-KEF     ex F-GTAL
Using hex code C0192E and c/s AC7185 currently heading north over southern England
GRaham
#4134
Hi Graham its in the database, there is an issue with the aircraft table updating but it should auto populate if set to do so, I have it on my box now and it is showing OK on the network.
diddyboy
Hi Alan
Guess what, yesterday it was N237SW, and now today It has been re-registered as 5Y-FAV.
Neil
I thought it would only be a matter of time Neil, all we need now is for it to squit its hex
diddyboy
Lets see what it brings up
Neil
Every chance it will keeps is US Hex but time will tell
