0 Members and 71 Guests are viewing this topic.
Morning Alan,
EVE1201 : LEXJ-LEMG
EVE1202: LEMG-LEXJ
EVE1117 : LEAL-LEXJ
EVE1118 : LEXJ-LEAL
EVE1111 : LEAL-LEBB
EVE1112 : LEBB-LEAL
Morning Ian,
Evening Alan, unknowns from Monday:
3C6DFC nothing more
4CA70C was EI-EAX ULAC, nothing about a new one with this reg/hex
502C67 was YL-BAC F50 until 2013, nothing about a new one with this reg/hex
MILs:
   3E9007  GAF263                                                         2016/01/18 08:27:17
* 3E9F1F        2016/01/18 08:34:02
* 3EA0EC  HG01B                                                          2016/01/18 13:22:07
* 3EA4EA  SPOOK1                                                         2016/01/18 16:40:33
   3F403D  SHOCK22                                                        2016/01/18 12:53:19
* 3F408A  GAF289                                                         2016/01/18 11:34:55
* 3F408A  GAF289                                                         2016/01/18 12:24:20
* 3F4FA3        2016/01/18 08:56:39
* 3F50AC  GAF709                                                         2016/01/18 07:18:49
* 3F50AC  GAF709                                                         2016/01/18 15:32:55
* 3F6786  APEX                                                           2016/01/18 14:13:04
* 3F6DA5        2016/01/18 20:35:01
regards Ingo
Hi Alan
Typo alert: 0C20AC HP-1842CMP is in the database as a B783 - should be a B738
Thanks again Ingo,
Nothing on your unknowns and mil tac added
all MILs have populated. A supplemental to 3FF450 D-MFVC, that I've posted yesterday: This airframe is owned/operated by Flugsportverein Celle. That's the reason for the registration D-MFVC.
Airframe has populated without operator.
Thanks again!
That's the operator in now Ingo, thanks again
X
510092,EW-395TH,0093499986,Ilyushin Il-76TD,Ruby Star Airways, thanks to Mark Pattenden
X
Afternoon Alan,
Is the aircraft table in the d/b now updating ok ? Not sure if these amendments have been made :
EC-MII A330-343E Evelop Airlines c/n 1691. New delivery, hex unknown.
EC-KVO B737-306F Swiftair c/n 23538/1288 transferred to Swift Air USA as N811TJ. New hex unknown.
EC-MIA B777-28ER Privilege Style c/n 28685 was on lease to Finnair but now on lease to El Al.
Hi Ian,
Still issues with the aircraft table, populate is OK though
345103,EC-MII,1691,Airbus A330-343E,Evelop,EVE,A333 added 19/12 and is in the Navdata
AB0EC5,N811TJ,23538/1288,Boeing 737-306F,Swift Air,,B733 also in the Navdata
EC-MIA is showing with El Al but is not in the Navdata
Evening Alan, unknowns from Tuesday:
3432D3 nothing more
3D190D  DEHSV aviation fanatic states, that this one is a Cessan 182K. I'm not able to confirm this information.
490D07 nothing more
MILs:
   3EBE8B  MUDDY                                                          2016/01/19 13:12:19
* 3F456A  POIS0N                                                         2016/01/19 17:18:11
   3F9DFA        2016/01/19 13:42:21
* 3FA107  LK01                                                           2016/01/19 13:28:18
   3FA10D  LK01                                                           2016/01/19 13:28:30
   3FBA09        2016/01/19 08:31:38
   3FBA09        2016/01/19 14:14:59
regards Ingo
Evening Ingo,
3D190D does indeed decode to D-EHSV.  However the C182 is not I-AMAQ so I presume that it has been re-allocated but I am unaware of its new guise.
Nothing on the other two and the mil tac added
falcon_nl
Unknown: 3C6DC4, Callsign GWI83M
