0 Members and 14 Guests are viewing this topic.
Hi Neil,
08004A,5H-SAV,208B5015,Cessna 208B Grand Caravan EX,Adventures Services
C05385,5Y-BVO,007,De Havilland Canada DHC-8-102 Dash 8,ALS/United Nations (Miscode hex of C-GFQI)
00A713,5H-FLC,UB-29,Beech 1900C,Flightlink Air Charters (Miscode hex of ZS-OUC)
Hi Les,
Thanks for that but please note that the same flight ID routes EHAM-SBCT-SBKP today on the return journey
I have no idea on it either X, could be anything.
I don't have anything on your others at this time.  Presumably 43EA84 M-ALIK is heading this way on delivery so hopefully it will be identified on arrival into Europe.
Good Afternoon Alan, unknowns from Thursday:
0C6480 nothing more
3C6F7E nothing more
3CAD64 nothing more
406D49 http://www.airport-data.com/aircraft/G-PICO.html
4CA5B9 nothing more
A9566F decodes N700VF currently no assigned or registered at FAA
A9CB14 decodes N730AJ, same as above
German MILs:
   3E8CBF  NITRO                                                          2016/01/21 13:53:33
* 3E8CF6        2016/01/21 13:19:21
* 3E9330        2016/01/21 13:03:56
* 3F58BC        2016/01/21 11:07:28
Regards Ingo
Afternoon Ingo,
406D49,G-PICO,11885,Cameron O-31,Jocelyn Frank Trehern,
Nothing on the others and mil tac added
Thanks again and enjoy your weekend.
falcon_nl
New one:
3DFFA1, D-HRBD, 0643 R66, Robinson R66
Any info yet for 3DAC4B   D-GLMP ?
Found this on the internet: http://flightaware.com/photos/view/329173-091c29eccd6d57c483fa203f6bcb4f03aa088383/all/sort/date/page/1/size/xga
#4236
From picture I would guess, that D-GLMP could be a Piper 34.
EDIT: of type PA-34-2?0? Seneca? or so.
Thanks falcon,
I saw D-HRBD on the network earlier and added it into the d/b
As Ingo states D-GLMP is a PA34 Seneca so that's a good start but its other wise unknown to me.
D-HRBD was in my range and has populated during the manual populate run. My other unknowns have populated too.
About D-GLMP: Too bad, no further information at your end. But sooner or later the blanks will be filled.
X
43EA84 M-ALIK is a Galaxy due into Luton later, nothing else known at this time, credit Dave on mode-s
CYYZGUY
Hi Alan, an unknown for me this evening.
It has been staying a 5700 Feet for quite some time.
A31C2E Mode-S
regards,
Jason
40" LED Monitor
40" LED Monitor
mikek
Not populating
C8230D, ZKFHR
ZK-FHR, R&B Bearhawk, 127-2491250-1249, Mr L J Fellman.
Cheers,
Mike
AoD
LOT31M   EPWA - LIMC
LOT5KL   EPWA - LKPR
company update:
49D254,   OK-PMC,   T-Air
Jason,
A31C2E decodes to N3RY which is not allocated at this time.  There are two previous users of the registration both US registered but I have not idea which one may be miscoding if either of them.  It will need to remain as an unknown at this time.
Mike,
C8230D,ZK-FHR,127-2491250-1249,R & B Bearhawk,L J Feltham
