0 Members and 17 Guests are viewing this topic.
Afternoon Alan,
it seems, that all the unknowns, that I've posted yesterday have populated.
Unknowns from Tuesday:
123180 nothing more
38125E nothing more
* 3E2766  DIGCS                                                          2016/01/26 10:33:28
* 3E2766  DIGCS                                                          2016/01/26 12:44:28
http://www.jetnetglobal.com/listings/aircraft/registry/184549/2011-KING-AIR-C90GTx-D-IGCS
458609 was OY-API B735, no information about a new one with this reg/hex
484187 was PH-HZM B738, no information about a new one with this reg/hex
4CA9B9 nothing more
73244F somehow I doubt that it was this one: http://www.airfleets.net/ficheapp/plane-a310-379.htm
A92DFA decodes N69061, is assigned by FA, but certificate is expired
EA03CB  no country allocation
EC00CB no country allocation
MILs:
* 3E87B7  BURNER                                                         2016/01/26 09:13:53
* 3EBCCD        2016/01/26 12:45:51
* 3F5721  GAF723                                                         2016/01/26 11:29:13
   3F58AA        2016/01/26 14:55:01
* 3F67AB  METAL1                                                         2016/01/26 13:23:36
* 3F69EF  NITRO10                                                        2016/01/26 09:22:01
* 3F760B  GAF640                                                         2016/01/26 08:00:28
* 3F760B  GAF640                                                         2016/01/26 11:42:24
* 3F7FCB        2016/01/26 13:30:03
   3F82E5  GAMC18                                                         2016/01/26 08:14:13
   3F82E5  GAMC18                                                         2016/01/26 12:11:55
   3F82E5  GAMC18                                                         2016/01/26 13:18:16
Regards Ingo
falcon_nl
#4276
Unknown :
49D38C callsign TVS124
4631CD callsign OHSWJ
Evening Ingo,
3E2766,D-IGCS,LJ-2009,Beech C90GTx King Air
Nothing on the others and mil tac done
#4278
falcon,
Nothing on the Czech register for 49D38C but I note from Skyliner that
49D38C,OK-TSM,34952/2426,Boeing 737-9GJER,Travel Service Airlines was delivered from Woensdrecht today so I presume that it will be this one.
Nothing yet on OH-SWJ, maybe M can assist with it.
Jason,
Nothing on C2AF57
Regarding SPR145, without the hex I have no chance to tie up
C0856A,C-GYNP,41257,AgustaWestland AW139,7506406 Canada
A6079D,N488PG,1053,Pilatus PC-12/47E,Krist Transportation
CYYZGUY
#4280
A64C72
AAF100
C03A5A
Only mode S showing, nothing else.
ACA765
No Routing
http://flightaware.com/live/flight/ACA765
regards,
Jason
40" LED Monitor
40" LED Monitor
Jason,
A64C72 decodes to N5049U a Beech test registration which is not currently in use.  The last holder of the registration is Be20 c/n BY-249 which became D-**** ON 16/1.  It may be it using its old ID
AAF100,N804CW,0804,Sonex,Chesley Wells Berry
C03A5A,C-FWCN,33698/1346,Boeing 737-7CT,WestJet no idea why its not already in the d/b.
X
Looks like B-MCF A320 Air Macau delivery via DWC
* 780EC4  AMU888   EDHI-VTBS                                             2016/01/28 08:18:27
* 780EC4  AMU888   EDHI-VTBS                                             2016/01/28 12:26:11
X
Looks like it X and it must have been an early departure from TLS as Skyliner has it as delivery 28-29jan16 TLS-DWC-RGN-MFM
780EC4,B-MCF,6934,Airbus A320-232,Air Macau,
Air Arabia A6-AOL is also due for delivery today as well so another for you to look out for
falcon_nl
#4284
Unknown: 3D6C9D callsign DFNJP
Found it, accourding to this page http://pilatus-history-and-news.blogspot.nl/2016/01/pilatusproduction-and-newsdecembre-2015.html
QuoteN   HB-FQI 16   PC-12/47E   1590   21-déc   Pilatus Flugzeugwerke AG   to D-FNJP
it a Pilatus PC-12/47E, sn 1590
Afternoon Alan,
EVE1113 : LEAL-GCXO
EVE1114 : GCXO-LEAL
MON265J : LEAL-EGKK
Also D-ABNT Air Berlin A320 c/n 2562 accompanying photo shows a Thomas Cook B757.
falcon_nl
#4287
Btw 4631CD, OH-SWJ is using now as callsign ABF2A (Scanwings)
Thanks Ian,
Hopefully sorted the photo issue, remember to delete the wrong one from your folder.
Thanks falcon I have asked on mode-s
