0 Members and 14 Guests are viewing this topic.
falcon,
As advised by Roger on mode-s, the Scanwings website states they now have 2 CitationJet CJ's so looks like it is a sister ship to OH-SWI. C/n details still unknown
GreekSpy2001
From Sky Liner
Airbus A320     -214     6942          A6-AOL     Air Arabia     delivery 28jan16 XFW-SHJ     ex D-AUBI
Just picked this up doing a loop in and out of British airspace over the North sea
* 896466  ABY998                                                         2016/01/28 14:15:41
Graham
Just added it in Graham.  Doing a UK airspace incursion on delivery to enable the lease financing to be signed off.
falcon_nl
Ok Thanks Alan and CN is not so important ;)
Afternoon/Evening Alan, unknowns from Wednesday:
3C6577 nothing more
3EA77B nothing more
Was in my range too:
* 4631CD  OHSWJ                                                          2016/01/27 13:42:26
485046 nothing more
4BA9D1 nothing more
AB0A99 decodes N810NS, currently not assighed or reserved by FAA
MILs:
* 3F4701  TA3                                                            2016/01/27 09:53:27
* 3F4701        2016/01/27 11:04:03
* 3F4701        2016/01/27 13:15:04
* 3F4701        2016/01/27 13:54:28
* 3F6631        2016/01/27 13:32:47
* 3F6631        2016/01/27 16:31:25
* 3F9C13  HORNET1                                                        2016/01/27 09:38:32
Regards Ingo
Hi Ingo,
485046,PH-HOY,GBS-029,Skystar Kitfox Mk 4-1200 Speedster
4631CD OH-SWJ details per previous reply
Nothing on the others mil tac added including 3EA77B which is in that range.
all now known unknowns have populated.
This weekend is the last weekend of this month and as I'm usually performing a database download update each last weekend of a month, I'd like to know if you know any problems or is it safe to perform the database download update.
Many thanks ahaead!
falcon_nl
New one from Toulouse
3C49D8, D-ABNX, 6927, A320, Airbus A320-214, Air Berlin, BER320P
Ingo,
The problem with the aircraft table has still not been fixed and the table in the Navdata has not been changed since 29th December.  The other tables are OK as far as I am aware.  It is therefore your decisions whether to update but I would suggest that you done and stay with populate at this time.
thanks, that's what I was afraid of. I'll stay with running populate cycles for now.
Regards Ingo
Michel
Alan,
VKG4858 GCLP-EKBI
Michel
Ingo,
3C4968 decodes to D-ABKH.  3C49D8 decodes to D-ABNX 3C49D6 decodes to D-ABNV
