0 Members and 20 Guests are viewing this topic.
X
44087C OE-IER A332 all white dep sandpit this am either ex A6-EAP or A6-EKQ
X
#4561
Hi X
Austrian register shows it to be c/n 525 so ex A6-EAP
44087C,OE-IER,525,Airbus A330-243,Waypoint GmbH,
A6-EAQ is already in the d/b under its new registration OE-IEQ
Good evening Alan, unknowns from Wednesday:
3FF1B6  DMESP https://www.luftfahrtclubbraunschweig.de/picdb/Torsten-Bleymehl-Gyro-Charter-GmbH-Comco-Ikarus-C-42-D-MESP-BWE-Braunschweig-Wolfsburg-13052.html
4CA1BC was EI-CZG B734 I found no indication of a new airframe using this reg/hex
4CA576 nothing  more
888888 nothing more
A92D6F decodes N69022 which is currently not assigned by FAA (Cancled)
MILs:
* 3E9FF2  SMOKE2                                                         2016/02/17 17:42:09
* 3F4765  SMOKE1                                                         2016/02/17 17:46:57
* 3F5071  RAVEN                                                          2016/02/17 14:10:20
* 3F5A92  GAF709                                                         2016/02/17 09:04:07
* 3F5AC4  STRIKE                                                         2016/02/17 14:17:54
* 3F614E        2016/02/17 12:13:02
* 3FA8A2  GATOR                                                          2016/02/17 13:20:00
* 3FBB1A        2016/02/17 09:28:41
Regards Ingo
Some today unknowns from Heidelberg area:
3CE91A  DCPOS still no luck with the details
MIL: 3F8472  VADER52
3FF422  DMTZA Magni Gyro M-24 Orion VIP http://www.skpage.de/SKpage/SKpage_Haupt/SKpage_Aviation/2015/SKpage_bot_Pleidelsheim-D-MTZA.html
https://www.facebook.com/Magni.Gyro.Srl/posts/1096748020336203
Regards Ingo
X
"A6-EAQ is already in the d/b under its new registration OE-IEQ"
I thought OE-IEQ was ex A6-EAM which left sandpit weeks ago!
X
Ingo,
3FF1B6,D-MESP,C42-0262,Ikarus C42B
3FF422,D-MTZA,,Magni M24 Orion
Nothing on the others and mil tac added
You are right X, must have had a brain storm
OE-IAQ is c/n 491 A6-EAQ is still with you.
X
After A6-EKQ departs I believe A6-EAF is next to go.
X
X
#4568
This one is not T7-MGA anymore but T7-JSJ Legacy as it got to 38000ft after seen departing DWC
* 5000B2                           T7-MGA     FDCT                       2016/02/19 01:35:19
And this is not HZ-ARD B789 (not delivered yet) as it was flying at 8000ft before descending into area!
* 71002D        2016/02/19 17:27:00
X
englishmark
Good afternoon Alan, unknowns from Thursday:
2EB267  BOMBER1 it seems, that we have a German MIL airframe that is permanently using a false hex. Including this record I got it five time during the past two weeks.
3DE546 nothing more
47AADE  LNFTT no further information
47ABF4  LNFTR no further information
48C405 nothing more
4BCCA0 nothing more
5081B0 nothing  more
888888  ABCDE someone testing his equipment?
940408 no country allocation
MILs:
* 3E9809  GHOST1                                                         2016/02/18 15:11:17
* 3F69A2  GAF767                                                         2016/02/18 13:13:36
* 3F75C1  GHOST2                                                         2016/02/18 15:12:41
* 3FBE5E  EIFEL                                                          2016/02/18 13:29:44
Regards Ingo
jim_stockwell
Hi Alan
Just back from a couple of weeks in Teneriffe and have a large number of routes that are not in the database. Is there any point in my sending them to you as they are probably winter schedules?
On another track is the c/n of D-CIRP correct? The database has it as 3007 but Airframes and a photo page have it as 3007!
Jim
Thanks X, the FDCT didn't remain with the hex long then.
5000B2,T7-JSJ,145540,Embraer ERJ 135BJ Legacy 600
I cant find anything on 71002D or on HZ-SK1 so will leave for now.
Hi Ingo,
3DE546 decodes to D-HHBQ but nothing found
47AADE  LNFTT nothing found, delivery?
47ABF4  LNFTR nothing found delivery?
Thanks again and have a good few days off work
Hi Jim,
If it is easy enough for you, you can send them to my email.  There is every likelihood that they are in the d/b but needing put through again.
D328 c/n 3007 was previously N471PS WFU and last noted fuselage only at Myrtle Beech in 2010.
D-CIRP is c/n 3006.
