0 Members and 20 Guests are viewing this topic.
Michel
Alan,
ABW552 EHAM-LIMC-UUEE iso ZBAA-UUEE
Michel
X
70C04B was used previously by A4O-AL which has been an AT42 and PC6T previously but no information what may be using it now.
760914 like you all I can find is info on the C172
Ingo,
Nothing on your unknowns, the mil tac added and checked again regarding 3F75C1 and can confirm it is in the d/b OK
Ingo, can you advise if your 2 mil tac populated please
M
ISR5675   LLBG   EFRO
ISR5676   EFRO   LLBG
ADR33D   EETN   ENGM
ADR34D   ENGM   EETN
ADR37A   EETN   ENGM
ADR38A   ENGM   EETN
ADR31T   EETN   ENVA
ADR32T   ENVA   EETN
ADR21A   EETN   ESSA
ADR22A   ESSA   EETN
ADR12T   EETN   EHAM
ADR14A   EHAM   EETN
ADR65E   EETN   EDDM
ADR66T   EDDM   EETN
ADR13T   EETN   EHAM
ADR11A   EHAM   EETN
Hi Alan, it seems that the whole populate function is dead. Non of the three MILs have populate. So I did a check with my secondary Box:
I received the two airframes below with my secondary box and ran two cycles of populate at 10:30UTC today. They didn't populate, but have populate on 24/7 Box yesterday afternoon/evening.
* 406F0A  MT6968                                                         2016/02/19 17:30:27
* 8963F3  UAE7380                                                        2016/02/19 17:26:40
Thanks Ingo,
I thought that would be the case.  I will advise Airnav.  Both those were added last night and are in todays update.  I have been trying to populate a new VOI A320 out of Toulouse without success and am just waiting for it to come into Myflights.  Its just come on and not populating.
0D0997,XA-VLO,6969,Airbus A320-214,Volaris as VOI9003
Morning Alan,
MON264 : EGKK-LEAL in d/b but needs recycling.
Also just left LEAL bound for EGPH is 406FD9 EZY45UV but not populating.
Thanks Ian, both recycled back in
Dave,
Regarding N4446N from last night.  Advised by Tony Scott Warren from Jersey that it is actually N4446M PA34 and should use hex A55CAF.  Therefore this is showing an incorrect hex and registration.
jacobite
Hi Alan, I seem to be having a problem anrb I did an update this morning and re-booted the update now all my registrations have disappeared. Help please if you can.
No idea, Ian.  I updated this morning and all OK.  I suggest that you do it again.
