0 Members and 15 Guests are viewing this topic.
jacobite
Hi Alan, there seems to be a lot of issues with db, I have downloaded the db recently and it seems it has a lot of problems. I had a flight this morning showing that D-AIMM was an A319 when should be an A388 it also has the owner as TAM and not Lufthansa. Is airnav server not working.
The server is working fine and the database is fine.  I have D-AIMM on screen this time inbound Frankfurt and its showing as an A388 with Lufthansa, see the attached.
#4667
Ian,
Also checked Mylog and as you can see it was also ok when I picked it up with my box as well.
The stuff you pick up with your box comes from your computer, check you Navdata to see if the entry for the aircraft is OK
jacobite
Quote from: Runway 31 on February 24, 2016, 09:33:20 AM
Ian,
I have checked the Navdata and D-AIMM is showing it as an A319. The routing is correct. I think that I will have to uninstall ANRB and start again, I have never had this happen before in all the time I have used ANRB and update it on a regular basis.
Morning Alan,
The following routes are in the d/b but require recycling as they have not shown up this morning :
JAF75G : LEAL-EBOS
EZY17VK : LEAL-EGCC
RYR42VG : GMFO-EBCI
falcon_nl
Unknown: 4CA5F9 callsign EIFNB
It would be easier just changing your Navdata entry. it must have got corrupted in some way on your computer as the Navdata database on the download and on the server is correct and that particular hex code has not seen any amendment since it was delivered.
I once got a  killed navdata db while under sync options "do not update manually changed records" was selected. Selecting the other option got me a new and uncurrupted db. Unfortunately that way all manual changes are gone. But if the db is already ill you won't have any other choise.
jacobite
Quote from: neroon79 on February 24, 2016, 11:08:11 AM
Hi Ingo, I done what Alan suggested but when I went back to check the db I found that they had all gone again. I have selected both options and I still have problems so it looks like I will have no choice but to re-install ANRB.
I have no idea how everything can disappear from your database as you state.
Just down load the Navdata as you will need to do that once you re-install.  There is a possibility that you have a corrupt Mylog so try deleting the data in it and start again with a fresh one.
#4675
Hi Ian, you can try to repair MyLog database. If it's corrupt, deleting content may not work. In that case you have to remove it from data folder of ANRB Software. The healing process is a little tricky but it worked for me in two cases were delete old data wasn't working anymore.
How to is here: http://www.airnavsystems.com/forum/index.php?topic=8476.msg116864#msg116864
Evening Alan, unknowns from Tuesday:
202480 no country allocation
3E36FB nothing more
3E53B6 nothing more
3FF40C  DMAXV www.shark.aero/index.php?option=com_ponygallery&Itemid=0&func=detail&id=866
504D55 nothing more
8963F7 nothing more
C2B3FB nothing more
MILs:
* 3E80C8        2016/02/23 10:44:49
* 3E824A  PACK32                                                         2016/02/23 18:12:04
* 3E8449        2016/02/23 11:10:36
* 3E9B8F        2016/02/23 13:34:11
* 3F5A58  SHOCK21                                                        2016/02/23 12:48:47
* 3F5A58  SHOCK21                                                        2016/02/23 18:11:22
   3F728D  RAGE1                                                          2016/02/23 14:43:55
* 3F9F2A  TIGER                                                          2016/02/23 13:29:47
Regards Ingo
Evening Ingo,
3E36FB - D-IMAD unknown to me
3E53B6 - D-IWXA unknown to me
3FF40C,D-MAXV,,Shark Aero Shark
504D55,ER-IAT,0003425746,Ilyushin Il-76T
8963F7,A6-EOZ,210,Airbus A380-841,Emirates not due till June so expect it to be a corrupt packet received
Nothing on the others and mil tac added
X
#4678
* 385DBB  FWNUJ                                                          2016/02/25 00:41:37
* 8A05C4  PKGQM                                                          2016/02/25 03:16:03
* 8A05C4  PKGQM                                                          2016/02/25 04:49:59
* E491FC        2016/02/25 09:20:11
* E49200        2016/02/25 09:23:12
* E49201        2016/02/25 10:01:16
* E49202        2016/02/25 10:12:23
Would assume PK-GQM is a A320 on delivery to Garuda Citilink
The last four probably Tucano trainers on delivery but there are five in AZI at the moment
X
M
BAW160   ZSPD   EGLL
BAW161   EGLL   ZSPD
PNX660   ESNU   ESNZ
PNX669   ESNZ   ESNU
ADR15B   EETN   EBBR
ADR16T   EBBR   EETN
ADR17B   EETN   EBBR
ADR18T   EBBR   EETN
ADR11A   EHAM   EETN
ISR225   LLBG   EFRO
ISR226   EFRO   LLBG
