0 Members and 15 Guests are viewing this topic.
X
385DBB  385DBB,F-WNUJ,VARIOUS,Various Aerospatiale Airframes,Aerospatiale Test Registration being used on this occasion by AT75 C/N 666 on delivery to Royal Star Aviation ex PP-PTX and I believe landed in OOMS for a technical stop
8A05C4,PK-GQM,6980,Airbus A320-214,Citilink added yesterday on departure from Toulouse and in todays update
E491FC PT-ZOG, E49200 PT-ZOL, E49201 PT-ZOM, E49202 PT-ZON last 4 E314 Tucanos on delivery to the Indonesia Air Force.  I have not added them to the d/b as they will change very soon when delivered.
falcon_nl
Unknown and no callsign 3D190D (D-EHSV?)
falcon
Forgot to post yesterday
4CA5F9,EI-FNB,17000093,Embraer 170-100LR ex ES-AEA inbound Exeter
4Morning Alan,
SAS1853 : ESSA-LEAL
CEL501 : LEMD-FGSL
VLG3148 : LEMG-LEPA
RYR61LZ : EGGP-LEAL
VLG3001 : GCLP-LEBL
VLG22CW : LEZL-LEBL
All these routes are in the d/b but need recycling. Seems an unusually large amount ?
Also did you get the routes in reply #4669 ?
Plus A986A2 not populating. No other details other than at FL120.
Many thanks Ian,
I imagine it will be due to populate etc being down, the routine will recognise they are time expired and will be trying to get to the server to check them but because it is down cant verify them so shows without the route details.  I got the other post but forgot to advise at thew time.
A986A2,N71257,208B5259,Cessna 208B Grand Caravan,Textron Aviation in the d/b since mid December, probably same as above due to you not updating your d/b
jacobite
Quote from: neroon79 on February 24, 2016, 06:03:44 PM
Hi Ian, you can try to repair MyLog database. If it's corrupt, deleting content may not work. In that case you have to remove it from data folder of ANRB Software. The healing process is a little tricky but it worked for me in two cases were delete old data wasn't working anymore.
How to is here: http://www.airnavsystems.com/forum/index.php?topic=8476.msg116864#msg116864
Hi Ingo, thanks for all your help, I tried this morning by reinstalling the software but it appears that some files in ANRB are corrupt. I have decided to do a clean install from my disc and see what happens, I will let you know what happens.
#4688
Nothing Ian but it should be EC-MJE an Air Nostrum frame re-registered, I believe it is out of Valencia doing an air test.
Got it now
345184,EC-MJE,7622,Canadair CL-600-2B19 Regional Jet CRJ-200ER,Air Nostrum/Iberia Regional ex OY-GRK
falcon_nl
Second unknown of today: 44A9F7 callsign JAF4218
I think there may be some corrupt data there falcon 44A9F7 decodes of OO-JOW which is not allocated
falcon_nl
#4691
Ok thanks Alan
Also found 2 new ones for you, maybe you got it already:
485316, PH-4N6, 16 SI 131, TL30, TL TL-3000 Sirius
485317, PH-4N5, 16 SI 130, TL30, TL TL-3000 Sirius
Yes got them falcon, thanks anyway
