0 Members and 16 Guests are viewing this topic.
X
From yesterday 43EB5B,2-GJSB,576,Aerospatiale ATR 42-512 ex A4O-AT as per Skyliner
jim_stockwell
Hi Alan
Took the plunge and upgraded to V6 yesterday and everything went well. (Even had several photos downloaded that had been missing before)
This morning, I started up and had to re-apply several of my preferences to get things back to how I like them, which was not a problem, but have been left with an "Aircraft History" series of boxes below the photo with no data in it. I don't really want it to show. Is there a way of getting rid of it?
If it is a feature that can't be removed, how and when does it get populated?
Thanks for any advice
Jim
X
   3C0800        2016/02/29 06:10:06
* 3ECC38  DKSHK                                                          2016/02/29 13:49:49
   468893  DAO188   HDAM-OMDB                                             2016/02/29 04:26:13
   468893  DAO189   OMDB-HDAM                                             2016/02/29 07:28:26
   613133        2016/02/29 00:38:24
   71002D        2016/02/29 00:00:00
* AE4D59        2016/02/29 08:48:02
* AE4D59        2016/02/29 09:37:28
* AE4D59        2016/02/29 11:27:59
The US code acts like a chopper as it is always at low altitude
X
Hi Jim
Top line, Tools/Show History, untick it
jim_stockwell
Hi Alan
As easy as that when you know how. Its Done!
Thanks for your help once again
Jim
X
3ECC38,D-KSHK,129,Schempp-Hirth Arcus M
468893,SX-BDS,879,Airbus A320-214,Daallo Airlines
71002D,HZ-SK1,1444,Gulfstream Aerospace G-IV-SP,Sky Prime Aviation Service my error with the hex in the d/b, now corrected
Nothing on the others
If you want to se it Jim, its gets the information from Mylog but as you didn't keep and use your previous on it is basically empty at this time but will grow through use.
Users upgrading should save the folders they want to keep such as logo's photos, silhouettes, outlines,  Mylog.db3 etc in a safe location then when  the upgrade is installed use them to replace what came with the installation.
Hi Alan
43C78C - current id TYPHOO69 - It has recently also used id ZK395 - a bit of a giveaway, coming from Warton!
Thanks Rod,
ZK395 became 1024 with the Saudi Air Force so guess its miscoding its old ID
Evening Alan, finally
3CE91A  DCPOS showed up at LAAS:
D-CPOS Cessna 560XLS+ 560-6109 (ex OY-GKC)
http://www.laasdata.com/corpjet/corpjet-by-type.php?t=19
Hello Alan, unknowns from Monday:
3FF401  DMGAE no further information
4CA904 was EI-BFR, no indications of a new airframe with this reg/hex
6CA24C no country allocation
ABC5BC decodes N858GX currently not assigned or reserved by FAA
E49247  TAM9952 http://xfw-spotter.blogspot.de/2016/02/a321-211sl-tam-d-ayah-pt-xpn-msn-7005.html But I guess it's already added to the db. As usual in my range before added to the db.
MILs:
* 3EAD13        2016/02/29 08:00:22
* 3EAD13  GAF007                                                         2016/02/29 14:47:16
* 3F4820  GUNNER                                                         2016/02/29 14:58:02
* 3F4820  ATTACK                                                         2016/02/29 19:18:05
* 3F5119  GAF274                                                         2016/02/29 07:30:49
* 3F5119        2016/02/29 09:27:43
* 3F5119        2016/02/29 13:46:59
* 3F60BD  GAF798                                                         2016/02/29 08:49:43
* 3F60BD  GAF798                                                         2016/02/29 10:23:39
* 3F6EDA  SHARK                                                          2016/02/29 13:46:53
* 3F7B87  KNIGHT                                                         2016/02/29 14:08:06
* 3F7B87  KNIGHT                                                         2016/02/29 15:37:48
* 3FBFBF        2016/02/29 09:26:32
* 3FBFBF        2016/02/29 13:20:31
Two MILs from today here in Heidelberg:
* 3F67A2  GAF219                                                         2016/03/01 15:57:00
* 3F94BA        2016/03/01 14:36:28
Hi Ingo,
E49247,PT-XPN,7005,Airbus A321-211,TAM Linhas AƩreas
Nothing on the others and mil tac added
Many thanks
falcon_nl
Unknown: 440866 callsign GAC299I
