0 Members and 23 Guests are viewing this topic.
#5235
Thanks again falcon
shark319
Wizz Air April update.
WZZ555   (W6 3101) LROP-EDDN
WZZ849   (W6 3102) EDDN-LROP (callsign still unchanged this month)
WZZ8LT   (W6 3369) LRCL-EDDN
WZZ7      (W6 3370) EDDN-LRCL
WZZ127   (W6 7735) LWSK-EDDN
WZZ1034 (W6 7736) EDDN-LWSK
Günter
falcon_nl
#5238
Unknown:
49C0F1 callsign OKTUA76
3E325F callsign DIKGT
Hawkeye
40701B showing in my log as G-EZPE.  Should it perhaps be G-EZPF?
Syd
Good Afternoon Alan, unknowns from Sunday:
1220C5 nothing more
3E17D6  DIAFM received again, still no luck with the details
3FF417  DMYAT received again, still no luck with the details
4006CC no active airframe found
4CA543 nothing more
A162EB decodes N189JH but is not assigned/reserved at FAA
Regards Ingo
Nothing on those Ingo, thanks again
you noticed 3ECD02  D-KSPE in reply 5241?
#5246
Yes Ingo and replied in 5244, oops sorry for some reason I thought it was from falcon??
Time I finished for the night, thanks again
#5247
Reply 5244 states thanks again falcon. So I didn't got that you were referencing to my heidelberg unknown.
Will do the same soon. Had a 10 hours day at work.
Michel
Alan,
IBK5912 GCLP-ESOK
EWG1423 EGNX-EDDL
GWI4UR EDDH-LEPA
TRA6391 EHGG-EHRD-LPFR
TRA6392 LPFR-EHGG
PRI524 GCFV-EKCH-EKYT iso GCFV-EKYT
AFR711W EDDH-LFPG
AFR775R ENGM-LFPG
AFR265T EKBI-LFPG
SAS86Y LEBL-ENGM
Michel
