0 Members and 16 Guests are viewing this topic.
falcon_nl
New on landing at AMS now:
48520B, PH-HXC, 41342, B738, Boeing 737-8K2/W, Transavia (TRA)
X
* A704D9        2016/04/05 09:40:48
This decodes to N551RD and nothing on FAA, over 1000 hits in 30 minutes between 2000 and 3500 ft.....light or chopper.
X
Morning Alan,
IBK5401 : EDDH-LEAL
JAF1793 : EBAW-LEAL
JAF1794 : LEAL-EBAW
ENT5108 : LEMG-EPWA
ENT5107 : EPWA-LEMG
Thanks falcon, it been in the d/b since first flight
X
A7049D,N551RD,M07SV6S0HK0130,Titan T-51 Mustang,Ronald K Dalin as per FAA
falcon_nl
#5256
Found a new one:
345117, EC-MIT, 5457, CL60, Canadair CL604 Challenger (ex D-AKBH)
Good Afternoon Alan, unknowns from Monday:
3FF32F  DMCFT no further information
3FF33B  DMHCB still no luck with the details
4B0129 nothing more
4CA673 EI-PII I haven't found any information about an active airframe (heli) with this reg/hex
4E438E no country allocation
505E92  OMATR
A2CE71 decodes N280ET not assigned or reserved at faa
MILs:
* 3E86D5  POISON1                                                        2016/04/04 08:46:21
* 3E88FC  POISON1                                                        2016/04/04 13:19:54
* 3F4109  GAF449                                                         2016/04/04 07:34:17
* 3F5418        2016/04/04 19:01:44
* 3F6340  GAF712                                                         2016/04/04 04:50:22
* 3F6340  GAF712                                                         2016/04/04 13:36:21
* 3F8A1C  NOBLE                                                          2016/04/04 07:21:23
* 3F8A1C        2016/04/04 12:01:11
* 3F918A        2016/04/04 18:59:03
* 3FB317  SHOCK12                                                        2016/04/04 13:26:46
regards Ingo
Thanks falcon, the operator is Excel Air
Afternoon Ingo,
4B0129,HB-ALL,411,Aerospatiale ATR 72-202F,Zimex Aviation,
505E92,OM-ATR,57143,Bell 429 GlobalRanger,Air Transport Europe had previously used 49D088 as a miscode
Nothing on the others and mil tac added
Many thanks
AoD
BMS2955   LRBC - EIDW
EXS8XN   EGNM - LKPR
the follwing MIL hasn't populated: 3F6340  GAF712
All other unknowns have populated.
Thanks Ingo
#5264
With thanks to Paul on mode-s below are the changes and additions to DOC8643 recently published.
These will be incorporated into the database in the coming days.  I am sure that the E170-200 change will cause me issues!!
AERO-EAST-EUROPE   SILA-450   S450   Landplane   Piston   1   L
AERONCA   65 Defender   AR6T   Landplane   Piston   1   L
AERONCA   Tandem (65)   AR6T   Landplane   Piston   1   L
AERONCA   65 Tandem   AR6T   Landplane   Piston   1   L
AERONCA   Tandem (60)   AR6T   Landplane   Piston   1   L
AERONCA   60 Tandem   AR6T   Landplane   Piston   1   L
AERONCA   Defender   AR6T   Landplane   Piston   1   L
AERONCA   50 Tandem   AR5T   Landplane   Piston   1   L
AERONCA   Super Chief   AR65   Landplane   Piston   1   L
AERONCA   65 Super Chief   AR65   Landplane   Piston   1   L
AERONCA   Chief (50)   AR50   Landplane   Piston   1   L
AERONCA   50 Chief   AR50   Landplane   Piston   1   L
AERONCA   Sea Scout   AERK   Landplane   Piston   1   L
AERONCA   Scout   AERK   Landplane   Piston   1   L
AERONCA   Tandem (50)   AR5T   Landplane   Piston   1   L
AERONCA   K Scout   AERK   Landplane   Piston   1   L
AERONCA   K Sea Scout   AERK   Landplane   Piston   1   L
AERONCA   Grasshopper   AR6T   Landplane   Piston   1   L
AERONCA   CF Scout   AERK   Landplane   Piston   1   L
AERONCA   YO-58 Grasshopper   AR6T   Landplane   Piston   1   L
AERONCA   O-58 Grasshopper   AR6T   Landplane   Piston   1   L
AERONCA   L-3 Grasshopper   AR6T   Landplane   Piston   1   L
AERONCA   Chief (11)   AR11   Landplane   Piston   1   L
AEROPUP   Aeropup   APUP   Landplane   Piston   1   L
AIRBUS   C-212   C212   Landplane   Turboprop   2   M
AIRBUS HELICOPTERS   H-225 Super Puma Mk2+   EC25   Helicopter   Turboprop   2   M
AIRBUS HELICOPTERS   H-120 Colibri   EC20   Helicopter   Turboprop   1   L
AIRBUS HELICOPTERS   H-125 Ecureuil   AS50   Helicopter   Turboprop   1   L
AIRBUS HELICOPTERS   H-125 SuperStar   AS50   Helicopter   Turboprop   1   L
AIRBUS HELICOPTERS   H-125 Fennec   AS50   Helicopter   Turboprop   1   L
AIRBUS HELICOPTERS   H-130   EC30   Helicopter   Turboprop   1   L
AIRBUS HELICOPTERS   H-135   EC35   Helicopter   Turboprop   2   L
AIRBUS HELICOPTERS   H-155   EC55   Helicopter   Turboprop   2   L
AIRBUS HELICOPTERS   H-225 Cougar Mk2+   EC25   Helicopter   Turboprop   2   M
AIRBUS HELICOPTERS   H-160   H160   Helicopter   Turboprop   2   L
AIRBUS HELICOPTERS-HARBIN   H-175   EC75   Helicopter   Turboprop   2   L
AIRBUS HELICOPTERS-KAWASAKI   H-145   EC45   Helicopter   Turboprop   2   L
AIRPLANE FACTORY   Sling 4   SLG4   Landplane   Piston   1   L
AIRPLANE FACTORY   Sling 2   SLG2   Landplane   Piston   1   L
ASTA   Hornet   F18H   Landplane   Jet   2   M
ASTA   AF-18 Hornet   F18H   Landplane   Jet   2   M
ASTA   ATF-18 Hornet   F18H   Landplane   Jet   2   M
ATR   ATR-72-212   AT73   Landplane   Turboprop   2   M
ATR   ATR-72-212A (600)   AT76   Landplane   Turboprop   2   M
ATR   ATR-72-212A (500)   AT75   Landplane   Turboprop   2   M
ATR   ATR-72-202   AT72   Landplane   Turboprop   2   M
ATR   ATR-72-211   AT73   Landplane   Turboprop   2   M
ATR   ATR-72-201   AT72   Landplane   Turboprop   2   M
AVICOPTER   AC-313   AC33   Helicopter   Turboprop   3   M
AVICOPTER   AC-301   AS50   Helicopter   Turboprop   1   L
AVICOPTER   AC-311   AC31   Helicopter   Turboprop   1   L
BAC   167 Strikemaster   STRK   Landplane   Jet   1   L
BAC   Strikemaster   STRK   Landplane   Jet   1   L
BEECHCRAFT   200 King Air 250   BE20   Landplane   Turboprop   2   L
BEECHCRAFT   Texan 2   TEX2   Landplane   Turboprop   1   L
BEECHCRAFT   3000 Texan 2   TEX2   Landplane   Turboprop   1   L
BEECHCRAFT   AT-6 Texan 2   TEX2   Landplane   Turboprop   1   L
BEECHCRAFT   T-6 Texan 2   TEX2   Landplane   Turboprop   1   L
BEECHCRAFT   300 (B300) King Air 350   B350   Landplane   Turboprop   2   L
BEECHCRAFT   King Air 90   BE9L   Landplane   Turboprop   2   L
BEECHCRAFT   Baron   BE58   Landplane   Piston   2   L
BEECHCRAFT   58 Baron   BE58   Landplane   Piston   2   L
BEECHCRAFT   King Air 250   BE20   Landplane   Turboprop   2   L
BEECHCRAFT   90 King Air 90   BE9L   Landplane   Turboprop   2   L
BEECHCRAFT   King Air 350   B350   Landplane   Turboprop   2   L
BELL   Relentless   B525   Helicopter   Turboprop   2   M
BELL   525 Relentless   B525   Helicopter   Turboprop   2   M
BELL   412 Griffin   B412   Helicopter   Turboprop   2   L
BOEING   NEA-18 Growler   F18S   Landplane   Jet   2   M
BOEING   FA-18E Super Hornet   F18S   Landplane   Jet   2   M
BOEING   FA-18F Super Hornet   F18S   Landplane   Jet   2   M
BOEING   EA-18 Growler   F18S   Landplane   Jet   2   M
BOEING   Growler   F18S   Landplane   Jet   2   M
BOEING   Super Hornet   F18S   Landplane   Jet   2   M
BOEING   777-8   B778   Landplane   Jet   2   H
BOEING   777-9   B779   Landplane   Jet   2   H
BOEING   FA-18D Hornet   F18H   Landplane   Jet   2   M
BOEING   Hornet   F18H   Landplane   Jet   2   M
BOEING   FA-18C Hornet   F18H   Landplane   Jet   2   M
BOEING   NC-135   C135   Landplane   Jet   4   H
BOLKOW   BO-207   KL07   Landplane   Piston   1   L
BOMBARDIER   E-11   GLEX   Landplane   Jet   2   M
BRITISH AEROSPACE   BAC-167 Strikemaster   STRK   Landplane   Jet   1   L
BRITISH AEROSPACE   Strikemaster   STRK   Landplane   Jet   1   L
CASA   SC-105 Amazonas   C295   Landplane   Turboprop   2   M
CESSNA   E350   E350   Landplane   Turboprop   1   L
CESSNA   Citation Latitude   C68A   Landplane   Jet   2   M
CESSNA   Citation M2   C25M   Landplane   Jet   2   L
CESSNA   525 Citation M2   C25M   Landplane   Jet   2   L
CESSNA   680A Citation Latitude   C68A   Landplane   Jet   2   M
CIRRUS   T-53   SR20   Landplane   Piston   1   L
COBALT   Valkyrie   CO50   Landplane   Piston   1   L
COBALT   Co-50 Valkyrie   CO50   Landplane   Piston   1   L
DAC   RangeR   RNGR   Landplane   Piston   1   L
DIAMOND   DA-42 Twin Turbo   DA42   Landplane   Piston   2   L
DIAMOND   Twin Turbo   DA42   Landplane   Piston   2   L
DIAMOND   DA-62   DA62   Landplane   Piston   2   L
DORNA   D-139 Parandeh Sefid   D139   Landplane   Piston   1   L
DORNA   Free Bird   D139   Landplane   Piston   1   L
DORNA   D-139 Free Bird   D139   Landplane   Piston   1   L
DORNA   D-139 Parandeh Abi   D139   Landplane   Piston   1   L
DORNA   Parandeh Sefid   D139   Landplane   Piston   1   L
DORNA   D-139 Blue Bird   D139   Landplane   Piston   1   L
DYN'AERO   Twin-R   TWIR   Landplane   Piston   2   L
EKOLOT   KR-030 Topaz   KR30   Landplane   Piston   1   L
EKOLOT   Topaz   KR30   Landplane   Piston   1   L
EMBRAER   ERJ-170-200 (long wing)   E75L   Landplane   Jet   2   M
EMBRAER   175 (long wing)   E75L   Landplane   Jet   2   M
EMBRAER   ERJ-170-200 (short wing)   E75S   Landplane   Jet   2   M
EMBRAER   175 (short wing)   E75S   Landplane   Jet   2   M
EMBRAER   ERJ-170-100   E170   Landplane   Jet   2   M
EPIC AIRCRAFT   Epic Victory   EVIC   Landplane   Jet   1   L
EPIC AIRCRAFT   Epic Elite   ELIT   Landplane   Jet   2   L
EPIC AIRCRAFT   Epic Escape   ESCA   Landplane   Turboprop   1   L
EPIC AIRCRAFT   Epic Dynasty   EPIC   Landplane   Turboprop   1   L
EPIC AIRCRAFT   Epic LT   EPIC   Landplane   Turboprop   1   L
EPIC AIRCRAFT   E-1000   EPIC   Landplane   Turboprop   1   L
FLYER   Flyer SS   FLSS   Landplane   Piston   1   L
FLYER   Flyer NG   FLSS   Landplane   Piston   1   L
FLYGFABRIKEN   LN-3 Seagull   LN3   Amphibian   Piston   1   L
FLYGFABRIKEN   Seagull   LN3   Amphibian   Piston   1   L
GAF   ATF-18 Hornet   F18H   Landplane   Jet   2   M
GAF   Hornet   F18H   Landplane   Jet   2   M
GAF   AF-18 Hornet   F18H   Landplane   Jet   2   M
HOWARD HUGHES   Australian LightWing Speed SP-4000   LW40   Landplane   Piston   1   L
JIHLAVAN   Skyleader GP One   GP1   Landplane   Piston   1   L
KAWASAKI   UP-1   P1   Landplane   Jet   4   M
KAWASAKI   P-1   P1   Landplane   Jet   4   M
LANCAIR   Evolution Turbine   EVOT   Landplane   Turboprop   1   L
MCDONNELL DOUGLAS   Super Hornet   F18S   Landplane   Jet   2   M
MCDONNELL DOUGLAS   FA-18E Super Hornet   F18S   Landplane   Jet   2   M
MCDONNELL DOUGLAS   FA-18F Super Hornet   F18S   Landplane   Jet   2   M
MCDONNELL DOUGLAS   Hornet   F18H   Landplane   Jet   2   M
MCDONNELL DOUGLAS   ATF-18 Hornet   F18H   Landplane   Jet   2   M
MCDONNELL DOUGLAS   FA-18C Hornet   F18H   Landplane   Jet   2   M
MCDONNELL DOUGLAS   FA-18D Hornet   F18H   Landplane   Jet   2   M
MCDONNELL DOUGLAS   KAF-18 Hornet   F18H   Landplane   Jet   2   M
MCDONNELL DOUGLAS   EF-18 Hornet   F18H   Landplane   Jet   2   M
MCDONNELL DOUGLAS   CF-188 Hornet   F18H   Landplane   Jet   2   M
MCDONNELL DOUGLAS   CF-18 Hornet   F18H   Landplane   Jet   2   M
MCDONNELL DOUGLAS   FA-18B Hornet   F18H   Landplane   Jet   2   M
MCDONNELL DOUGLAS   FA-18A Hornet   F18H   Landplane   Jet   2   M
MD HELICOPTERS   AH-6I   H500   Helicopter   Turboprop   1   L
MIL   Mi-35 Caribe   MI24   Helicopter   Turboprop   2   M
MIL   AH-2 Sabre   MI24   Helicopter   Turboprop   2   M
MIL   Sabre   MI24   Helicopter   Turboprop   2   M
MIL   Caribe   MI24   Helicopter   Turboprop   2   M
MITSUBISHI   MRJ-70   MRJ7   Landplane   Jet   2   M
MITSUBISHI   MRJ-90   MRJ9   Landplane   Jet   2   M
PATRIA   FA-18 Hornet   F18H   Landplane   Jet   2   M
PATRIA   Hornet   F18H   Landplane   Jet   2   M
PELEGRIN   Tarragon   TARR   Landplane   Piston   1   L
PHOENIX AIR   Phoenix   U15   Landplane   Piston   1   L
PHOENIX AIR   U-15 Phoenix   U15   Landplane   Piston   1   L
PIPISTREL   Taurus Electro G2   PITE   Landplane   Electric   1   L
PIPISTREL   Taurus 503   PITA   Landplane   Piston   1   L
PIPISTREL   Taurus Electro G4   PIT4   Landplane   Electric   1   L
PIPISTREL   WattsUp   PIAE   Landplane   Electric   1   L
PIPISTREL   Alpha Electro   PIAE   Landplane   Electric   1   L
PIPISTREL   Surveyor   PIVI   Landplane   Piston   1   L
ROTORSMART   HeliSmart   HSMT   Helicopter   Piston   1   L
SCHEIBE   Turbo Falke   SF25   Landplane   Piston   1   L
SCHEIBE   SF-25 Turbo Falke   SF25   Landplane   Piston   1   L
SF   FA-18 Hornet   F18H   Landplane   Jet   2   M
SF   Hornet   F18H   Landplane   Jet   2   M
THK   T-19 Turkkusu   T19   Landplane   Piston   1   L
THK   Turkkusu   T19   Landplane   Piston   1   L
THK   T-19 Speedfire   T19   Landplane   Piston   1   L
THK   Speedfire   T19   Landplane   Piston   1   L
TL ULTRALIGHT   Stream   STRE   Landplane   Piston   1   L
VALMET   Hornet   F18H   Landplane   Jet   2   M
VALMET   FA-18 Hornet   F18H   Landplane   Jet   2   M
WACO   CLASSIC 2T-1   G2T1   Landplane   Piston   1   L
WESTLAND   Apache   H64   Helicopter   Turboprop   2   M
WESTLAND   WAH-64 Apache   H64   Helicopter   Turboprop   2   M
