0 Members and 23 Guests are viewing this topic.
We are not having any luck today falcon, another one I can find no details on
falcon_nl
yang
Mode-S code: 8990EE
Registration: B-09590 (not B-9590)
Type: Boeing 737-79U(BBJ)
cn: 61040
X
I think it was A704D9 I picked up the other day and must have got a bit of dyslexia! It should be N551TP I picked up and not N551RD,. N551TP is now Pakistan Army reg 303 c/n FL-303
"A7049D,N551RD,M07SV6S0HK0130,Titan T-51 Mustang,Ronald K Dalin as per FAA"
X
Hi Yang,
8990EE is already in the d/b as you detail since 2/4
8990EE,B-09590,61040/5279,Boeing 737-79V BBJ
Thanks X
A704D9,303,FL-303,Beech B300 King Air 350,Pakistan - Air Force (miscode hex of N551TP)
Afternoon Alan,
IBK5326 : LEAL-ENRY not GCTS-EFOU
EC-KJU AW109 c/n 11709 is in the d/b as belonging to Helisureste. It is actually with INAER.
Alan,
Couple of d/b changes :
OM-EEX B737 of Air Explore is no longer with Ryanair. It has come over operating AXE2120 out of LIRF but no info as to where it is going.
YL-LCM A320 is also no longer with Ryanair as it has come over operating TVS5RU of Travel Service Airlines routing LKPR-GCFV.
Cheers Ian, thanks again
Good Morning Alan, unknowns from Wednesday:
071964 no country allocation
3C56E0 nothing more
3C66B6 nothing more
3D3BA1  DEUVH no luck with the details
3FF401  DMGAE no luck with the details
3FF45C  DMLKW http://www.flugzeugbilder.de/show.php?id=1416352 (at least one identified)
40061D no active airframe found
45C926 nothing more
804211 nothing more
86D240 nothing more
AB0B1A http://registry.faa.gov/aircraftinquiry/NNum_Results.aspx?omni=Home-N-Number&nNumberTxt=N810TW
ADD778  N991ML http://registry.faa.gov/aircraftinquiry/NNum_Results.aspx?NNumbertxt=N991ML
MILs:
* 3EA1FD  GAF712                                                         2016/04/06 07:03:38
* 3F6221  GAF709                                                         2016/04/06 08:02:50
   3F8856        2016/04/06 10:28:11
* 3FA86C        2016/04/06 07:31:47
Regards Ingo
Unknowns from Thursday:
3CC576 nothing more
3CDD36  LHB2 no further information
3D1BB7 (received two times) https://planefinder.net/data/aircraft/D-EITB
3D3B58  DEUSM https://planefinder.net/data/aircraft/D-EUSM
424304 http://xfw-spotter.blogspot.de/2016/03/a321-211sl-aeroflot-d-ayau-vp-bav-msn.html
47A419 nothing more
4A28BC nothing more
4B38C7 no active airframe found
8694B2 nothing more
B0B0A9 no country allocation
EC03C2 same as above
MILs:
  3EA1FD  GAF712                                                         2016/04/07 10:00:55
* 3F6F67  GAFN69A                                                        2016/04/07 08:58:19
Regards Ingo
falcon_nl
New one from Hamburg:
AD646E, N962JT, 6988, A321, Airbus A321-231, JetBlue Airways (JBU)
Hi Ingo
Thursday
3D1BB7,D-EITB,3528,Cirrus SR22
3D3B58,D-EUSM,40.618,Diamond DA 40 Star
424304,VP-BAV,7037,Airbus A321-211,Aeroflot Russian Airlines
Nothing on the others and mil tac done
Wednesday
3C66B6,D-AIUV,7174,Airbus A320-214,Lufthansa due August so probably corrupt packet
3FF45C,D-MLKW,102/2014,BRM Aero Bristell
AB0B1A,N810TW,101,Waco RTO,William F Natale something tells me not it!!
ADD778,N991ML,RB-254,Raytheon 390 Premier 1A,ATI Engineering Services
Many thanks
