0 Members and 111 Guests are viewing this topic.
Jason,
A48F81,N393SC,35-650,Learjet 35A,SC Aviation
Many thanks
No idea on that one X, it does not decode so suspect its a corrupt packet or a miscode
Morning Alan,
JAF9AX : LEAL-EBCI
EIN575 : LEAL-EIDW
JAF98T : LEAL-EBCI
JAF6EH : EBCI-LELC
JAF5EX : LELC-EBCI not LEMG-EBBR
BEE4PD : EGCN-LEAL not EGHI-EIDW
BEE8MC : LEAL-EGCN not EDDV-EGBB
X
#5538
I sent an email regarding JY-PTC. I miscodes as both 744282 JY-PTB and 744284 JY-PTD. It landed at Medina as one and took off as the other! It also appears in db as 896375 JY-PTC ex A6-ABM and appears occasionally in My Logs as such but this might be corrupt packages as it is on both G9/ABY and FZ?FDB f/n's.
X
X
As you state this was probably VH-OQF with corrupt package as it is 7C4925. It was in the area at the time
    7C0925        2016/04/24 00:00:00
X
X
PS the only way to tell if it is actually JY-PTD flying is it uses G9/ABY flight codes, if it is JY-PTC miscoding as JY-PTD it uses 9P/PTR ex Petra Airlines codes
X
I wish they would just sort them out X, nuisances!!
superspotter
Hi Alan;
Further to my recent posting regarding 5N-BTR hexcode 0641D0. I can confirm it is an S-76 and am quite sure but not positive, that it is operated by Bristows Nigeria.
regards clive.
Good Afternoon Alan,
unknowns from Sunday:
3D2760  DESBA no luck with the details
3D71F3  DFPKD http://www.tosta.de/techno-classica-04-2016/  https://www.flickr.com/photos/134293798@N08/26098687390
MIL: 3F4A88  HG01A
3FF4A6  DMTPL still no luck with the details
   471EA1  WZZ5BL   EPWA-EGGW                                             2016/04/24 11:47:53
   471EA1  WZZ5WN   EPWA-EBCI                                             2016/04/24 17:41:49
both caused by 471EA5, don't know if it's a coincidence that I have two false entries of the same airframe or if the airframe has a dodgy transmitter.
4AC92A received to times / nothing more
ACC69F decodes N922LN which is not assigned or reserved at FAA.
Regards Ingo
From today at Heidelberg:
MIL: 3F4FE2  GAF113
3FF3BF  DMYSK (three times) no further information
Many thanks Clive,  added in with that info
Ingo,
3D2760,D-ESBA,,Piper PA-46-500TP Malibu Meridian (miscode)  c/n unknown
3D71F3,D-FPKD,,Piper PA-46-500TP Malibu Meridian again no c/n
Nothing on your others from the two posts, mil tac added and no idea of the transponder.
Many thanks
Michel
Alan,
CND612 LGIR-EHAM iso HEGN-EHAM
TRA368 LGIR-EHGG-EHRD iso HEGN-EHAM
TRA426 LTAI-EHAM iso LGPZ-EHAM
KLM24K ESGG-EHAM
Michel
