0 Members and 48 Guests are viewing this topic.
diddyboy
Hi Alan
A couple from yesterday in the Swansea area.
* 440C85        2016/04/26 04:56:42
* A874CA        2016/04/26 15:35:55
Neil
X
#5567
896000/8961FB/896375 should be marked as various as they are constantly on my box as unknowns. Sometimes they are on EK/EY/G9 and FZ f/ns and 896000 many times on many different choppers.
   896000        2016/04/27 10:34:14
   896000        2016/04/27 11:57:14
   896000        2016/04/27 13:36:18
   896000        2016/04/27 14:18:23
   8961FB        2016/04/27 07:32:00
X
Good Day Alan, unknowns from Tuesday :
3CC783 nothing more
3CDCB4 nothing more
3D3BA1  DEUVH The daily ADS-B equipped unknown that I'm not able to get any details on.
3DAC49 nothing more
3DB145  DGNJP received two times, no further information
3E4490 nothing more
4CA50E no active airframe found
A795EC decodes N588ZN which is not reserved or assigned at FAA
MILS
* 3EA665        2016/04/26 13:58:55
* 3EA665  DRAGON                                                         2016/04/26 14:35:49
* 3F7BA1  MONSTR                                                         2016/04/26 14:03:02
* 3F8F59  SEAL                                                           2016/04/26 10:22:01
Regards Ingo
X
OMA633  OOMS-OMAA                 A4O-ED     E170  Oman Air             2016/04/27 10:41:48
OMA669   OOMS-OTHH                 A4O-EA     E170  Oman Air             2016/04/27 09:06:26
OMA931   OOMS-OOKB                A4O-EB     E170  Oman Air             2016/04/27 13:43:00
OMA932   OOKB-OOMS                A4O-EB     E170  Oman Air             2016/04/27
X
Afternoon Alan,
Just had KC130J 167112 c/n 5602 of USMC (Flight ID Otis64) come over accompanied by an Osprey both at 9000ft. I take it you have nothing on the Osprey ?
X
ETD246  OMAA-VOCI                 A6-AEH     A321  Etihad Airways       2016/04/27 03:16:10
ETD393  OMAA-OTHH                 A6-AEI     A321  Etihad Airways       2016/04/27 09:10:25
ETD681  OMAA-HTDA                  A6-EIX     A320  Etihad Airways       2016/04/27 08:52:54
X
X
Obviously a renumbered f/n after the crash of A6-FDN!
FDB935  OMDB-URRR                 A6-FDM     B738  flydubai             2016/04/27 00:00:00
FDB936  URRR-OMDB                 A6-FDM     B738  flydubai             2016/04/27 06:51:20
X
Nothing on either of those Neil,
440C85 does not decode and A874CA decodes to N644HD which is not allocated
X,
I THOUGH 896375 was JY-PTC using the hex if its old ID A6-ABM, is that not the case now.
Ingo,
3D3BA1  D-EUVH is noted on Scramble as visiting Amsterdam 25/4 but no type mentioned
Nothing on the others and mil tac added
Many thanks for the route info X
I didn't pick up either of them Ian.  I take it the Osprey was not squitting?
Alan,
Osprey not squitting. I wonder when the make ADSB mandatory, if that will include Ospreys ?
X
#5579
Hi Alan
896375 has been picked many times on my system and on searching My logs, when c/s is picked up on many occasions seems to be using f/ns of other airlines (e.g UAE/FDB/ETD) so looks more like they are corrupt messages.
JY-PTC is now always miscoding as either JY-PTB (744282) or JY-PTD (744284) but always uses ex 9P/PTR ex Petra f/n's...as you said a real nuisance! The real JY-PTD always uses ABY f/n's on its flights to from Amman to SHJ.
X
