0 Members and 23 Guests are viewing this topic.
falcon_nl
New ones and one unknown:
3FF44E, D-MEBP, 174, WT9, AeroSpool WT9 Dynamic NG
3D31D6, D-ERCW, 4636298, PA46, Piper PA46-350P Malibu Mirage
3FECEF, D-MMPY, C42, Comco Ikarus C42
3D10C1 callsign DEEPD
Thanks again falcon, nothing on D-EEPD
Good Afternoon Alan, unknowns from Sunday:
12C707 nothing more
3CD9D3  DCJUH no further information
3D0B82  DECPM no further information
3D14A2  DEGBI http://www.skybird-ev.de/Germany/puetnitz/f-gamm-puetnitz-d.html
3D2279  DELHP http://www.luftsportverein-flensburg.de/neuigkeiten-und-aktivitaeten-motorflug  http://www.luftsportverein-flensburg.de/downloads/download/16-d-elph-cessna-172-p/68-d-elhp-flughandbuch-c172p
3D4195  DEXBX http://www.lsc-duempel.de/programm/item/65-teilnehmeroam.html http://www.lsv-treuchtlingen.de/?page_id=1377
3D5207 nothing more
3E1ACE  DIBIS (twice) who had thought that: http://d-ibis.de/index.html
3E2DFD nothing more
3E607B  DKBST http://www.sfg-telgte.de/index.php/flugzeuge29/flugzeuge-unterwegs23
3E6D16 nothing more
3EDA45  DKXPT http://haxterberg.de/edlr_web/unsere-flotte/segelflugzeuge/d-kako-2
3F51F3 MIL?
3FF12B  DMEPS http://www.flugzeugforum.de/threads/54970-Flugplatz-Schoenhagen-EDAZ/page185
3FF362  ZZZZZZZZ no further information
3FF4D0  DMWHA https://static1.squarespace.com/static/55b1c6bbe4b0527caaf11713/t/56ec3f4007eaa0e20bf21d40/1458323397782/Benutzerhandbuch.pdf It's the smaller one ;-) http://www.flugzeugbilder.de/show.php?id=1352882
operator /owner https://flugschule-hannover.squarespace.com/remos/
406CC5 G-CIKB http://www.rcawsey.co.uk/duodis2.htm
4240B2 no active airframe found
4407F1 nothing more
4850DD nothing more
4851E0 nothing more
4CA236 nothing more
78070C nothing more
A8F778 reserved but not assigned: http://registry.faa.gov/aircraftinquiry/NNum_Results.aspx?omni=Home-N-Number&nNumberTxt=N677TX
E96496 no country allocation
Miscoded Airframe:
888888  DKJCB twice with high message count:
http://www.onlinecontest.org/olc-2.0/gliding/flightinfo.html?dsId=4891140
http://segelwiese-canitz.de/2016/?module=stfw-anmeldung&options=view;0002.xml;
Regards Ingo
Three MILs from Heidelberg area today:
* 3F4D86        2016/06/06 06:41:34
* 3F7B32  GAF120                                                         2016/06/06 07:47:55
* 3F9176        2016/06/06 06:41:28
Evening Ingo,
3CD9D3,D-CJUH,560-6206,Cessna 560XL Citation XLS+
3D14A2,D-EGBI,61113,PZL 104 Wilga 35A
3D2279  DELHP still the two links refer to D-ELPH
3D4195,D-EXBX,,Extra EA-300/LC
3E1ACE,D-IBIS,,Cessna T303 Crusader,Ibis Charter
3E2DFD nothing more
3E607B,D-KBST,226,Schempp-Hirth Duo Discus XLT
3EDA45,D-KXPT,257,Schempp-Hirth Duo Discus T
3F51F3 mil tac
3FF12B,D-MEPS,08-05-17,Flight Design CTLS
3FF4D0,D-MWHA,030,Remos Gemini Ultra
406CC5,G-CIKB,235,Schempp-Hirth Duo Discus T,DD3 Group
4407F1,OE-CHL,227,Europa Aviation Europa,Friedrich Neusser
4850DD,PH-PAF,1051,Kubicek BB100Z
4851E0,PH-1562,29708,Schleicher ASW-27-18E
888888  DKJCB nothing from the link
3D10C1,D-EEPD,4692138,Piper PA-46-350T Malibu Matrix
Nothing on the others and mil tac added
Many thanks
I overcame my "dyslexia episode". Here is the "real" finding for D-ELHP: http://www.airnieuws.nl/movements/texel/apr16/index.html
Sorry and thanks!
Please explain what you want to tell me. D-KJCB is DG-808C manufacturer DG Flugzeugbau GmbH. The hex is false of course.
Thanks!
Hi Ingo,
3D2279,D-ELHP,,Van's RV-7
When I tried the link I got an error message, not available however
888888,D-KJCB,8-431B330X90,DG Flugzeugbau DG-808 C,(Miscode)
juliomb179
ARE3197 SKMR-SKBO
ARE3024 SKBO-SKRG
FC8085 SKBO-SKRG
Julio.
M
QTR755   OTHH   KATL
QTR756   KATL   OTHH
BTI3KB   BIKF   EVRA
FIN921   EFHK   LBWN
FIN922   LBWN   EFHK
FIN4EA   EFHK   LIPX
FIN271   EFHK   EFTP
ROT336   ESSA   LROP
SAS2739   ESSA   LGMK
SAS2740   LGMK   ESSA
AEE4538   LGSA   ESNU
AEE4539   ESNU   LGSA
RLU5571   ULLI   LYTV
RLU5572   LYTV   ULLI
SDM5791   ULLI   LGKR
SDM5792   LGKR   ULLI
SCW266U   ESSB   ESNU
SCW361F   ESNZ   ESSB
SCW362F   ESSB   ESNZ
#6147
Morning Alan,
EXS6AZ : LEAL-EGNT
EZY2980 : GCRR-LIMC
Had on 'My Flights' Cirrus SR22 EC-KST c/n 2837. The flight ID was EC-KST but the registration shows as EC-KCT. Checked with Spanish register and it should be EC-KST.
X
This aircraft is now using PXA flight codes (it used PAX as per one of my previous posts) which means it is operating for Pecotox Air of Moldovia. I have it up to 31500ft so assume is a large Jet....They operated An-74's but this maybe a Ilyushin if the An-74's are all known.
  504E37        2016/06/07 13:16:35
X
Good Afternoon Alan, unknowns from Monday:
39ADE8 nothing more
3C0C98 nothing more
3FF33B  DMHCB still no luck with the details
3FF3BE  DMZTG http://www.tragschrauberservice.de/blog/
424312 nothing more
440108 no active airframe found
458D9D nothing more
45A4C6 nothing more
468680 nothing more
4B191D nothing more
4BCCBC nothing more
4CA9B1 twice / 1,5 hours between the two receptions
76CD13 nothing more
AAE5F9 http://registry.faa.gov/aircraftinquiry/NNum_Results.aspx?omni=Home-N-Number&nNumberTxt=N801EA
MILs:
* 3E85E5  GAF067                                                         2016/06/06 10:59:45
* 3E8AE7  GAF655                                                         2016/06/06 07:47:14
* 3EAC69  HAWK409                                                        2016/06/06 09:25:02
* 3F94E2        2016/06/06 11:48:44
* 3F94E2        2016/06/06 18:22:41
* 3FAFFD        2016/06/06 11:05:19
Regards Ingo
