0 Members and 54 Guests are viewing this topic.
CYYZGUY
40" LED Monitor
40" LED Monitor
Many thanks AoD,
Nothing on the miscode
3E47E2 decodes to D-ISKO no other info.
49C001 isn't on the Czech register
Hi falcon
49D150,OK-OKB,F1720528,Reims F172H Skyhawk,OK-Air
3E49F6 decodes to D-ITFA presumably a typo but D-IFTA and D-ITFA are both unknown to me
Many thanks
eagle11
VLG8380:  LEBL – EHBK
VLG8381:  EHBK – LEBL
Frans
jim_stockwell
Hi Alan
A few unknowns from the last couple of daysE48419,5102CD with a flight I/D of T7-HAS AND 0200F1
sorry I didn't see any of them so can offer no help
Jim
Hi Jim,
E48419,PR-AGP,680-0259,Cessna 680 Citation Sovereign,Global Taxi Aereo
5000CD,T7-HAS,14501195,Embraer ERJ 135BJ Legacy 650,Aviation Horizons/Empire Aviation note the hex it is different from the one you gave, can you confirm what you picked up as it looks like it may be miscoding
Nothing on your other one
Many thanks
jim_stockwell
Hi Alan
You are correct, a bit of finger trouble, hex was 5102CD and not 5002CD. Sorry
Put it down to the vino!
Jim
jim_stockwell
Can you check the C/N of OK-SWTplease.
The database has 28346 while GAS has 29346
Jim
Thanks Jim,
I will add in the miscode 5102CD which is a Belarus hex?? in addition to its correct 5000CD.  I presume it is a one box miscode as it has also been noted using its correct hex.
Amended OK-SWT
Thanks again.
Good Afternoon / Good Evening Alan, unknowns Monday 18th July:
2EB466  BOMBER1 (miscoded MIL, hex: no country allocation)
MIL: 3EBA3E  APEX
3EC15F  DKOEP http://www.edmy.de/fotogalerie/impressionen/d-koep-im-morgengrauen-321.html
MILs II.
  3F7FB7        2016/07/18 07:22:55
   3F7FB7  NOBLE1                                                         2016/07/18 11:41:13
   3F7FB7  RAVEN1                                                         2016/07/18 16:17:29
   3F97BE  GAFM51                                                         2016/07/18 10:40:32
3FF33B  DMHCB still no luck with the details
Regards Ingo
Sunday 17th July:
D-IMPO four times, still no luck
3FF4A6  DMTPL no luck with the details
US MIL: AE5C8E  GRZLY78
Friday July 15th:
3D1AC5  DEIJT http://www.flugzeugbilder.de/show.php?id=1407981 http://www.planecheck.com/index.asp?ent=da&id=30595&cor=y
3D2111  DEKTT not 100% sure about type etc.
MILs:
* 3F4999  JUDGE1                                                         2016/07/15 07:21:42
   3F7FB7  IRON2                                                          2016/07/15 07:09:23
* 3F85F4  GAF242                                                         2016/07/15 06:24:29
* 3F85F4  GAF242                                                         2016/07/15 10:12:27
* 3FA75D  GAFE13                                                         2016/07/15 08:19:55
* 3FBCC3        2016/07/15 08:05:57
* 3FBCC3        2016/07/15 08:50:48
3FEBD4  DMGTH https://www.facebook.com/EDLBspotting/photos/a.864636970224540.1073741828.864624726892431/1121922441162657/?type=3&theater http://www.flugzeugforum.de/threads/70529-Flugbetrieb-in-Borkenberge-EDLB/page51
