0 Members and 19 Guests are viewing this topic.
Many thanks AoD
49875A nothing on Czech register with this hex, possibly military and can find nothing on the other 2 either
Judwin45
Hi Alan
2 amendments, apologies if you all ready have them.
31FEFD, AW149, CSX81890, cn 49024.
43C47E, HH-101A Mk.611, ZR356, cn50251.
Both at Farnborough.
Keith
5 miles south of EGDY
Good Afternoon, Good Evening Alan, unknowns July 19th:
3D0FC2 at two different times, nothing more
MILs:
* 3E971B        2016/07/19 07:27:52
* 3E971B        2016/07/19 16:24:29
* 3EB1FB        2016/07/19 09:09:59
* 3EB1FB  MOJO1                                                          2016/07/19 13:00:14
* 3EBA6D  RAGE                                                           2016/07/19 13:42:59
* 3F4324  BOMBER2                                                        2016/07/19 13:44:53
* 3F5B2C  BOMBER1                                                        2016/07/19 13:35:04
   3FF362  ZZZZZZZZ                                                       2016/07/19 09:22:52
   3FF401  DMGAE                                                          2016/07/19 16:24:17
3FF401  DMGAE still no luck with the details
3FF427  DMVGT still no lluck with the details
A3A354 N3330H http://registry.faa.gov/aircraftinquiry/NNum_Results.aspx?omni=Home-N-Number&nNumberTxt=N3330H   Designator: ERCO
Regards Ingo
Hi Keith,
Regarding ZR356 I think there is a problem with its c/n you detail as c/n 50251 went to the Nigerian Air Force as NAF-280 in 2014.  ZR356 is due to become MM81868
Many thanks
Afternoon Ingo,
3D0FC2 decodes to D-EEFI but can find nothing on it
A3A354,N3330H,3955,Erco 415-C Ercoupe,Victor F Beil,
3FF362 is not mil but nothing on it
Nothing on the others and mil tac added
Many thanks
Judwin45
Your right Alan, my mistake should be 50261.
Keith
Keith
Sorry, I copied the MILs further than I intended. Must be the weather 35°C, no clouds and almost no wind.
shouriken
4A4C6C - YR-SCL - DV20 - Diamond Aircraft DA-20-A1 Katana - Regional Air Services - 10.021
4A16E5 - YR-EWE - E300 - Extra EA-300L - Aeroclubul Romaniei - 106
4A16E6 - YR-EWF - E300 - Extra EA-300L - Aeroclubul Romaniei - 107
Liviu
A.net JetPhotos.Net
RadarBox
falcon_nl
The list from today :
3FEBB7, D-MNIL,  WT9, Aerospool WT9 Dynamic
3FF49,  D-MPSG, CH60, Zenair CH.601 Zodiac
3FEC29, D-MOHP, GOLF, Tecnam P96 Golf 100
3FD94C callsign DOTSM
505D86 callsign OMKLF
3FEEDB callsign DMYHY http://www.d-myhy.de/
falcon
I have 3FEC29 D-MOHP as a III Sky Arrow 450 TGS  http://www.jetphotos.net/photo/8043187
Can you give the full hex of D-MPSG
3FD94C,D-OTSM,90/122,Ultramagic S-90
3FEEDB,D-MYHY,01-09-51-098,ICP MXP-740 Savannah
505D86,OM-KLF,,Cirrus SR22
Many thanks
falcon_nl
D-MPSG 3FF4A9
Thanks for the other one's,  Alan
