0 Members and 16 Guests are viewing this topic.
paul tricker
one from yesterday
3FF038  DMZEC
D-MZEC  Zenair CH.602
no other details found, & I don't keep records of these little things
Paul
Many thanks Paul, cant find the c/n either
X
#6557
We appear to have a new airarabia A320
* 896485  ABY998                                                         2016/07/21 05:45:25
and a KC135? miscoding, correct c/s and heights for one anyway
* AE825E  PYTHN48                                                        2016/07/21 00:59:47
* AE825E  PYTHN48                                                        2016/07/21 08:39:12
Might be AE025E 61-0264 which is in the area but if so only had a eight hour break at Al Udeid before miscoding
X
X
Added in this morning
896485,A6-AON,7225,Airbus A320-214,Air Arabia
Regarding AE825E I have no information on it
Judwin45
43C7DB now being used by AW-101-612 ZZ100 c/n 50262 1st for Norway A.F.
Keith
5 miles south of EGDY
Cheers Keith, that's what we have.
Good Afternoon Alan, unknowns July 20th:
300641  IVICC http://www.flugzeugbilder.de/show.php?id=946598 http://www.gavs.it/rci.php?matricola=VICC http://www.jetphotos.net/photo/7763139
3D2111  DEKTT no further information
3D47B8  DEZKI https://planefinder.net/data/aircraft/D-EZKI http://www.flugzeugbilder.de/show.php?id=1428968
MILs:
* 3E8009        2016/07/20 12:25:57
   3E877F  VIRUS1                                                         2016/07/20 08:02:22
* 3E9478  VIRUS1                                                         2016/07/20 13:45:08
* 3F7EDF  ZAPATA                                                         2016/07/20 08:16:28
3FF4B1  DMDIG still no luck with the details
Regards Ingo
Evening Ingo,
300641,I-VICC,016,Partenavia P 68B,Compass Air
3D47B8,D-EZKI,2002536,Van's RV-7
Nothing on the others and mi ltac added
Many thanks
falcon_nl
Only unknowns today :-)
3D1690 callsign DEGAQ
3D1491 callsign DEGAR
3CCA06 callsign EFD222
paul tricker
B787-9 G-CIXO (62082/450) arrived at LGW this morning using the code 47C88C.
Whether it will be re-coded or re-registered before entering service I don't know
Paul
Many thanks Paul, should be coded 40702A.
falcon
3D1491,D-EGAR,,Grob G 120TP no c/n and had N198TP under the wings
3D1690,D-EGAQ,,Grob G 120TP,(Miscode allocated 3D1490), had N192TP under the wing both landed Prestwick.
3CCA06,D-CDUS,525C-1061,Cessna 525C CitationJet CJ4,Eisele Flugdienst
Afternoon Alan,
That's the visitors away back home, so now back in business :
RYR91HF : LEAL-ENRY
RYR61AG : LEAL-EIKY
IBK5421 : EFHK-LEAL
VOE2429 : LEAL-LFBD
VOE2428 : LFBD-LEAL
VLG3967 : LEVC-LEZL
Michel
Alan,
BEL306 ESSB-EBBR
TRA73P EHAM-LIRP
DAL467 LLBG-KJFK iso UUEE-KJFK-KSLC
CND511 EHAM-LBBG iso EHAM-LLBG
Michel
Many thanks Ian, nice to have you back on board
