0 Members and 17 Guests are viewing this topic.
juliomb179
AV8373 (GLG8373) SKBO-SEQM
ARE3164 SKBO-SKBG
FC8152 SKBO-SKCG
Julio.
Good Morning Alan, unknowns Thurday July 21st:
3CE968  DCPRS http://www.rzjets.net/aircraft/?reg=434076 https://planefinder.net/data/aircraft/D-CPRS
3D34AF  DESEX https://planefinder.net/data/aircraft/D-ESEX http://www.flugzeugbilder.de/show.php?id=1428471
MILs:
* 3E8383  GAF526                                                         2016/07/21 08:41:57
* 3E871E  GATOR                                                          2016/07/21 07:51:19
* 3EB103  VIRUS                                                          2016/07/21 09:28:22
* 3F6053  GAF910                                                         2016/07/21 10:23:17
* 3F6053  GAF910                                                         2016/07/21 13:34:24
* 3F8853  MIG                                                            2016/07/21 09:25:07
3FF502  DMKTE no further information
Regards Ingo
Unknows Friday July 22nd:
MILs:
3E8383  GAF526
3E8A65        2016/07/22 10:16:12
3EB221        2016/07/22 07:19:21
3F8E08        2016/07/22 07:19:39
3FF445  DMMTG no further information
3FF4EE  DMVLY no further inforamtion
A8B22B  N66D is Reserved but currently not assigned at FAA
Have a nice Saturday.
Morning Ingo
3CE968,D-CPRS,FL-631,Beech B300 King Air 350
3D34AF,D-ESEX,AT01-323A,Aquila AT01-100A,
Nothing on the others and mil tac added over the two days
Many thanks
Afternoon Alan,
Couple for you :
ISS73VA : LIME-GVAC
IBK8YG : LEAL-EKYT
CYYZGUY
Hi Alan, a Canadian Unknown
Mode-S C01045
Flight ID CFGEE
Nothing else.
regards,
Jason
40" LED Monitor
40" LED Monitor
Evening Ian.  Thanks again
Hi Jason,
C01045,CF-GEE,28-3819,Piper PA-28-180 Cherokee C,R & J Perrett
Many thanks
AoD
AZA8015   ESSA - LIRF
DLH4RJ   ESGG - EDDM
IBE6888   ZSPD - LEMD
MNB267   EHAM - LTBU - OTHH
OHY476   EDDT - LTBA
Morning Alan,
CFG1150 (DE1150) EDDV - LGKO
CFG1151 (DE1151) LGKO - EDDV
Unknowns Saturday July 23rd:
3C70B3  BCS001Z https://www.planespotters.net/airframe/Boeing/757/29442/D-ALES-EAT-Leipzig and FR24
3FEC5A  DMBIB (2x) http://www.lph2o.com/library/databases/aircraft-database/list/25?resetfilters=0&limitstart25=1468950&group_by=airplanesregister___model
3FF2F4  DMRUB http://gyrotrixy.blogspot.de/2016_07_01_archive.html
3FF4A5  DMSYL http://www.jetphotos.net/showphotos.php?regsearch=D-MSYL
3FF515  DMJXX http://www.rotorspot.nl/historic/d-2.php
48477F  DFAXI (4x) https://planefinder.net/data/aircraft/D-FAXI
The hex decodes to PH-WAA, which had an accident on Isle Ameland in 2012 no records since then. So I presume possibly damaged beyond repair.
A8B22B  N66D again, received two times on two boxes
Have a nice Sunday!
Morning Alan,
IBE31SV : LEMD-LGAV
EZY35NE : GMMX-LIMC
EXS2HA : EGNT-LELC
EXS958 : LEAL-EGCC
ISS279 : LIML-LEIB
RYR75RE : EGGP-LEAL
IBK8921 : EKCH-LEAL  This is a possible positional flight as it does not appear on the arrivals board. Route info from FR24.
Afternoon Ingo,
3C70B3,D-ALES,29442/819,Boeing 757-2Q8F,EAT Leipzig
3FEC5A,D-MBIB,,Aeropro Eurofox 2K
3FF2F4,D-MRUB,035,Trixy G4-2
3FF4A5,D-MSYL,2016-4231,Evektor EV-97 SportStar,Evektor,
3FF515,D-MJXX,,AutoGyro MT-03
D-FAXI is in the d/b under its correct ID 3D4BAE,D-FAXI,862,Pilatus PC-6/B2-H4 Turbo Porter,Air Evex Westfalia/FAXI Flugzeugvermietung  I have added it in under the miscode as well.  It was due to become PH-AXI at one time but was ntu so presumably that is where it got the Dutch hex
A8B22B  N66D no idea, the only previous use I can find was a PTS1 now b/u
Many thanks and enjoy whatever is left of your day before you get on the train
