0 Members and 28 Guests are viewing this topic.
#6645
Clive,
It is ET-AOK that is using the incorrect hex as it is allocated code 040011.  040021 was allocated to ET-AMQ but it has left the fleet and is now VQ-BUO.  If my memory serves me correct both aircraft were using 040021 and it was in the d/b previously as VARIOUS and being used by both.  I will now re-enter 040021 as ET-AOK miscoding.
#6646
Thanks JD, A4D11F N4095H is in the database as a Cessna Test Registration.  Hopefully I-FVLB gets recoded very soon after delivery.
Many thanks falcon
3FF4AD,D-MSLA,8506-1102,Ikarus Sherpa II
Nothing on DMMDF
Thanks Ingo, nothing on D-MAUD
jim_stockwell
Evening Alan
One not populating earlier today was 5000D7 with a flight i/d of T7-SBH
Jim
Hi Jim,
5000D7,T7-SBH,19000225,Embraer Lineage 1000
Many thanks
Michel
Alan,
TRA1306 LTFE-EHAM
TFL166 LWOH-EHAM
TFL663 EHAM-LGRP
TCX98PG EGCC-LCPH
TOM2HT LCPH-EGPH iso LEPA-EGCC
Michel
Many thanks Michel.  BTW TOM2HT has been in the d/b since 9/5
Morning Ingo,
I am not sure what you mean regarding D-ESTT, there is no SR20 with this registration in the database.  It became F-HGTL and was changed in the database 15/10/2015
3D3631,D-ESTT,4636075,Piper PA-46 Malibu Mirage JetPROP DLX
3FF4B5,D-MLTM,,Rans S-6 Coyote II
45E293,OY-XTS,5E118S17,DG Flugzeugbau DG-500/22 ELAN
Many thanks
For some reason the old D-ESTT was still in one of the three local db I'm using, althaugh all were updated by db download between now and October 2015. I have now manually deleted the old D-ESTT in local db and removed details from MyLog db. After running a populate cycle the problem was solved.
Thanks Ingo
superspotter
Hello from Lagos;
Hexcode 06C004 is in the Airnav Db as HR-AVN L1011 and states a miscode of TL-ADW.
It is in fact now TL-TSM 733 of Karinou Airlines, currently descending into Cotonou airport from Malabo.
regards clive.
Hi Clive,
06C004,TL-TSM,28560/2888,Boeing 737-36N,Karinou Airlines
The hex was used for the previous ID of HR-AVN which was TL-ADW and its still flying as far as I am aware
Many thanks
AoD
Hi Alan
ADR327   LFPG - EPLL
FLI7041   LGKF - EKCH
SXS778   LTCA - EDDV
BEL1848   EPKK - EBBR
49D337, OK-JIR, Piper PA28, 28-7505098, Aeroklub Tábor
502CCB callsign YLIES
49C022 callsign OKOUR04
506C08
