0 Members and 23 Guests are viewing this topic.
Evening Ingo
Hannover
3D128C,D-EFGU,2024,Cirrus SR20,
3E5DDE,D-KATA,920419,Let L-13SDL Vivat,
3FF24A,D-MXPS,C42-0126,Ikarus C-42B
3FF3CB,D-MNEE,,ASO 26 Storch
3FF410,D-MBUC,,Ikarus C42B
4D3D5A,D-EVMG,18281775,Cessna 182T Skylane,(Miscode allocated 3D3D5A),
Darmstadt
3D1757,D-EHBZ,0006,Zlin Z-143L,
3D25F6,D-EMPY,10112,Diamond DA20-A1 Katana
407052,G-IPPL,F17201348,Reims F172M Skyhawk,Aeroclub Schweighofen Wissembourg
43EA97,M-MSVI,525B-0361,Cessna 525B CitationJet CJ3,JPM Ltd in the d/b since April
Nothing on the others and many thanks again
#6796
X
I have nothing on AE1E4E.
Here is a photo of it while it was an MC-130J http://www.jetphotos.net/showphotos.php?regsearch=12-5753 unfortunately the serial is not completely visable on the tail.
How reliable was the sighting of the plate with the year 11-
Guess we shall just have to wait until it flies again
falcon_nl
A list from today again :)
3FEA4A, D-MEVB, PNR3, Alpi Aviation Pioneer 300
4267F1 callsign DVK28
A8B22B callsign   N66D (again, and still no info on FAA)
3D0FC6 callsign DEEFM (this time with callsign)
Hi falcon,
this one 3D0FC6 callsign DEEFM (this time with callsign) was posted be me with details yesterday morning.
If you run populate out of MyFlights menu it should be added to your local db. Important: two cycles are necessary to update MyFlights db.
You may consider to always do this before posting unknowns. It will avoid double postings and safe some of Alan's time.
Hi Ingo, falcon doesn't use a radarbox and does not have access to our database
Hi falcon,
Sorry don't have details on any of them
#6801
OK, thank's Alan,
in that case forget what I posted falcon.
Alan, unfortunately according to your reply to the post were I posted D-EEFM it seems that you mixed it up with an other unknown.
See next post.
I posted: 3D0FC6  DEEFM http://www.lufthans.net/charterpreise.htm
You stated: 3D0F36,D-EEFM,275,Robin R 2160 Alpha Sport,
http://www.fliegerverein.eu/ikarus/
Hi Ingo,
3D0FC6,D-EEFM,,Cessna 172SP Skyhawk SP c/n unknown
The Robin is in correctly as 3D127E D-EFGG and the entry for 3D0F36 has been deleted, no idea where that came from :-))
#6804
No problem. If falcon hadn't posted it again, I wouldn't have noticed it.
Maybe it was a short episode of BFS (brain fatigue syndrome).
falcon_nl
#6805
Quote from: Runway 31 on August 07, 2016, 07:28:43 AM
3FED6D,D-MTTL,267,Remos GX
4B4E5C,PH-1546,36819,Diamond HK36TTC Super Dimona,(Miscode hex of HB-2485)
The PH-1546 is the imported HB-2485 and still not recoded to dutch code. Parked at Teuge  (EHTE)
And the D-MTTL belongs to Luftsportverein Treuchtlingen-Pappenheim
And I always check before I post ☺
Thanks for the operator update falcon.
For info we mark the miscode in the operator field of the database to show that it is a miscode.  I check all details as well (Still get them wrong at times :-))
X
As per my email earlier it may never fly again and therefore the most expensive ground trainer ever at $48million!
X
falcon_nl
Quote from: Runway 31 on August 08, 2016, 06:17:38 PM
Still waiting for the box being sent ;-)
Still waiting on it being sent :-))
