0 Members and 120 Guests are viewing this topic.
Afternoon Andrew,
A couple for you :
LLP8397 : LEMG-EPKT
TOM68A : LEAL-EGFF
orkney
Hello Ian Terry and J.D
Thanks for all of them, They are done.
Andrew
Good Afternoon/Evening Andrew, unknowns Sep. 12th:
3C669C  DJJ XNP no further information
MIL/TAC German Airforce etc.
* 3E8205  SCARE                                                          2016/09/12 13:14:33
* 3E887B  GAF123                                                         2016/09/12 06:35:57
* 3E887B        2016/09/12 09:25:20
* 3F52D3  GAM8648                                                        2016/09/12 14:18:29
* 3F99C7        2016/09/12 06:14:50
* 3F99C7        2016/09/12 10:24:32
* 3FBBB4  GAF163                                                         2016/09/12 06:44:33
3FF3C8  DMYJJ still no luck with the details
3FF516  DMWJS no further information
Regards Ingo
Sep. 11th:
3FF13C  DMAUD still no luck with the details
3FF239  DMWAA Operator/Owners Website: http://luftsportverein-milan.de/html/remos_d-mwaa.html
3FF2D6  DMMSE still no luck with the details
3FF3C8  DMYJJ posted with Sep. 12 unknowns
Regards Ingo
diddyboy
Hi Alan
Some unknowns around the London area today.
* 3C4502  MHV1                                                           2016/09/13 06:21:01
* 400931        2016/09/13 13:43:37
* 440541        2016/09/13 11:20:36
* 484964        2016/09/13 13:42:43
* 4CA58C        2016/09/13 15:47:06
* A02CF8        2016/09/13 13:09:23
   CD2C92        2016/09/13 13:09:23
   FA2CC3        2016/09/13 13:09:23
Neil
orkney
Hello Terry Neil and Ingo
I have done all of them now. Sadly I cannot find information for many of your unknown ones Neil and Ingo.
Andrew
Good Afternoon / Evening Andrew, unknowns Sep. 13th:
3E2503  DIFFF https://forum.luftfahrtclubbraunschweig.de/viewtopic.php?t=4914&p=41595#p41595
MIL/TAC of GAF:
* 3EA12B  THOR71                                                         2016/09/13 07:51:02
* 3EA12B  THOR71                                                         2016/09/13 09:39:20
* 3EA88D        2016/09/13 08:43:20
* 3EA88D  RACER2                                                         2016/09/13 16:07:12
* 3EB43C        2016/09/13 09:37:20
* 3EB6DF  THOR72                                                         2016/09/13 08:49:07
* 3EB6DF  THOR72                                                         2016/09/13 09:42:54
* 3F6A5D  BOMBER75                                                       2016/09/13 08:30:02
* 3F7FD0        2016/09/13 09:09:32
* 3F8B4A        2016/09/13 09:37:51
* 3FA8ED  BOMBER76                                                       2016/09/13 09:01:50
* 3FB3DF  EIFEL2                                                         2016/09/13 08:13:57
* 3FB45B  GAF639                                                         2016/09/13 08:44:59
3FF332  DMEYY still no luck with the details
3FF38A  DMYEL no luck with the details either
3FF427  DMVGT still no luck with the details
4AB545  SEMJE http://www.laasdata.com/turbos/turbo-by-type.php?t=6 http://www.jetnetglobal.com/listings/aircraft/registry/18349/1994-KING-AIR-B200-SE-MJE https://www.flickr.com/photos/42014593@N05/29304249472/
Regards Ingo
Kenny
880861  HS-BCG  Cessna 172S  c/n 172S10568  ex N981JA  op Bangkok Aviation Center
880461  HS-ACA  Cirrus SR22T  c/n 0118  ex N118TH  op AC Aviation
885963  HS-VKC  Airbus A320-214(WL)  c/n 6878  ex VN-A664  op ThaiVietJetAir
Kenny
ANRB 3km north of VTBD
orkney
Hello Kenny, Ingo and Terry
That should be all of them done now.
Andrew
paul tricker
#7164
* 5000C9  T7BSA
Just went overhead into STN/LTN
No other details other than it was a biz jet of some sort
Paul
I have been advised it *should* be G450 c/n 4115  ex VP-BSA
orkney
Hello Terry and Paul
That should be them all done.
Andrew
Afternoon Andrew,
ENT812 : LELC-LKPR not LEMD-LKPR
New GAF tactical code : 3F4F74 using flight ID 'Devil 43'.
Afternoon / Evening Andrew, unknowns Sep. 14th:
3E46E6  DISAW no further information
MIL/TAC: 3EAD1E  GAF120
3FF427  DMVGT Still no luck with the details
48DEE4  SPYYE no further information
orkney
Hello Ingo, Ian and Terry
That should be the known ones done. I cannot find anything for the unknown ones either.
Thanks Again
Andrew
Michel
Hi Andrew,
AFR1264 LFPG-EKBI
AFR1337 EHAM-LFST
TRA5006 LDDU-EHAM
TRA1616 LGSM-EHAM iso LGMT-EHAM
TRA2B EHRD-EDDB iso LEIB-EHAM
TFL5JT LGKP-EHAM
TFL8HX LBBG-EHAM
LLC141 EGCC-LGZA
LLC142 LGZA-EGCC
IBK5078 LEMG-EKYT
CND412 LGIR-EHAM iso LLOV-EHAM
BMR67BD EGGD-EDDL
Michel
