0 Members and 100 Guests are viewing this topic.
CYYZGUY
I have what appears to be a Mig 17 flying around my area..16,000 Feet
Can you confirm this info is correct?
Mode-S AD79DD
Reg N968
regards,
Jason
40" LED Monitor
40" LED Monitor
Michel
Alan,
IBK5913 ESOK-GCLP
VKG1515 GCLP-ENRY
Michel
That's what the FAA say Jason
shark319
Wizz Air October update.
WZZ501   (W6 3101) LROP-EDDN
WZZ484   (W6 3102) EDDN-LROP
WZZ542   (W6 3369) LRCL-EDDN
WZZ928   (W6 3370) EDDN-LRCL
WZZ643   (W6 3767) LRSB-EDDN
WZZ894   (W6 3768) EDDN-LRSB
WZZ82W  (W6 4343) LBSF-EDDN
WZZ973   (W6 4344) EDDN-LBSF
WZZ3754 (W6 7735) LWSK-EDDN
WZZ258   (W6 7736) EDDN-LWSK
Günter
#7340
Thanks again Terry.
The airline themselves consider it to be CAVOK Airlines http://www.cavok.aero/ and the info I have is that it is an An-12BK but all the info on the web gives it as a BP so happy to go with that.
Good Morning Alan,
I was "grounded" by Job since September 15th. Now as I'm on holiday I found some time to process my backlog. As usually I'm starting with the MILs (20 lines per post):
*   3E803E   SCARE               26.09.2016 18:21
   3E82D8   GAF019               07.10.2016 11:22
   3E82D8   GAF288               30.09.2016 10:19
   3E82D8   GAF277               27.09.2016 11:32
   3E82D8                  27.09.2016 14:21
   3E82D8   GAF014               26.09.2016 12:52
*   3E83E0   GAF244               07.10.2016 06:14
*   3E83E0                  07.10.2016 13:56
*   3E842D   BU22T               20.09.2016 13:53
*   3E84EC                  06.10.2016 10:39
   3E8539   GAF045               28.09.2016 05:35
   3E8539                  28.09.2016 09:23
   3E8812                  06.10.2016 06:23
   3E8812   BARON               29.09.2016 07:42
   3E8812   SPIDER1               28.09.2016 14:21
*   3E8812   HG01B               21.09.2016 17:04
*   3E88B2                  21.09.2016 13:01
   3E88B4   ATTACK3               10.10.2016 13:35
   3E88B4   STRIKE2               07.10.2016 08:31
   3E88B4   KNIGHT               21.09.2016 13:04
Regards Ingo
MIL Backlog Batch 2:
*   3E88B4   APEX               20.09.2016 08:10
   3E8939   GAF757               27.09.2016 13:44
*   3E89AC   PANTER               10.10.2016 12:58
*   3E89AC                  10.10.2016 17:52
*   3E89AC   SW80               10.10.2016 18:44
*   3E8AC0   GAF188               16.09.2016 08:52
   3E8BC3                  28.09.2016 11:51
   3E8BC3   GAF045               27.09.2016 06:06
   3E8D76   SCARE               10.10.2016 10:35
   3E8D76                  06.10.2016 17:28
   3E94F2   GAF126               29.09.2016 08:28
   3E94F2   GAF063               27.09.2016 09:49
*   3E94F2   GAF789               26.09.2016 08:28
   3E983C   GAF186               06.10.2016 08:20
*   3E9A9B   ROCKET1               10.10.2016 08:31
   3E9B73   MONSTR1               10.10.2016 12:52
   3E9B73                  10.10.2016 17:55
   3E9B73   SW81               10.10.2016 18:57
   3E9B73   PANTER               06.10.2016 12:48
   3E9B73   SW03               29.09.2016 07:58
Batch 3:
*   3E9B73   PUMA               23.09.2016 07:42
   3E9C84   GAF423               16.09.2016 10:15
   3E9D74   GAF131               02.10.2016 16:18
   3E9D74                  29.09.2016 10:30
   3E9D74   GAF383               29.09.2016 12:15
*   3EA034   GAF757               27.09.2016 07:50
*   3EA034                  15.09.2016 08:36
   3EA38A   GAF712               05.10.2016 11:35
   3EA38A   GAF138               28.09.2016 17:39
*   3EA38A                  27.09.2016 08:57
   3EA8E8   ATTACK2               10.10.2016 13:49
*   3EAB70                  28.09.2016 06:46
   3EAB72   GAF223               07.10.2016 20:07
   3EAB72   GAF126               05.10.2016 12:32
   3EAB72   GAF192               29.09.2016 15:12
   3EAB72   GAF423               27.09.2016 12:26
*   3EAB76                  26.09.2016 07:15
   3EABCD   SHOCK11               10.10.2016 07:21
   3EABCD   VADER22               10.10.2016 13:40
   3EABCD                  26.09.2016 08:41
Batch 4:
   3EABCD   PACK31               26.09.2016 12:55
   3EABCD   SHOCK2               21.09.2016 12:25
*   3EABCD   GAFK31               19.09.2016 12:05
   3EACE2   KNIGHT               04.10.2016 18:51
   3EACE2                  27.09.2016 08:15
   3EACE2   ATTACK               26.09.2016 17:42
*   3EAF80                  26.09.2016 13:01
   3EB183                  05.10.2016 06:39
   3EB187   GAF228               05.10.2016 06:14
*   3EB2AB                  30.09.2016 08:44
   3EB40D                  27.09.2016 16:47
*   3EB40D   HG01B               19.09.2016 17:05
   3EB63C                  29.09.2016 12:48
   3EB63C   SNIPER2               29.09.2016 17:33
   3EB63C   TORO1               28.09.2016 17:44
   3EB7A9                  07.10.2016 11:08
   3EB7A9   GAF007               07.10.2016 13:44
*   3EB7A9   LIFTER1               05.10.2016 09:26
   3EB96B   GAFN74               07.10.2016 13:51
*   3EB96B   LK01B               28.09.2016 12:27
Batch 5:
*   3EBC87   HG01B               22.09.2016 16:57
*   3F4346   HAWK407               10.10.2016 13:50
   3F4AD5                  05.10.2016 17:38
   3F4AD5   LANCE1               26.09.2016 17:45
*   3F4B13                  10.10.2016 10:16
   3F4B29   GAF059               23.09.2016 08:02
   3F4B29                  23.09.2016 14:23
*   3F4B71                  15.09.2016 12:08
*   3F5178   SEAL               29.09.2016 12:07
   3F54D3                  10.10.2016 12:03
   3F54D3   TORO1               05.10.2016 17:33
   3F54D3   RAVEN1               23.09.2016 11:21
*   3F5FB8                  06.10.2016 13:23
   3F6384   PACK12               26.09.2016 08:44
   3F6384   PACK33               26.09.2016 13:02
*   3F6384   SHOCK12               23.09.2016 08:02
   3F6384   GAFK31               16.09.2016 06:52
*   3F6384                  15.09.2016 07:44
   3F682F   DARK1               10.10.2016 12:14
   3F682F                  06.10.2016 06:23
Batch 6:
*   3F682F   SPIDER2               28.09.2016 14:21
*   3F682F   SPIDER               28.09.2016 18:32
   3F6A83   GAF221               21.09.2016 07:20
*   3F6A83   GAF234               19.09.2016 06:58
*   3F6C2F   GHOST1               04.10.2016 18:45
   3F72AE                  10.10.2016 11:40
   3F72AE   RAVEN2               10.10.2016 16:28
   3F72AE   NOBLE               05.10.2016 17:08
*   3F72AE   JUDGE1               29.09.2016 17:50
*   3F7936   RAGE1               05.10.2016 07:15
*   3F7936                  05.10.2016 12:45
   3F7BC9                  10.10.2016 12:14
*   3F7C26   GAF123               10.10.2016 10:58
*   3F8449                  23.09.2016 08:38
   3F845A                  10.10.2016 11:39
*   3F8558   GAF288               29.09.2016 07:45
*   3F8558   GAF277               29.09.2016 18:29
   3F85D2   SPIKE02               29.09.2016 08:59
*   3F860B   GAF007               27.09.2016 06:40
*   3F860B                  27.09.2016 09:15
Batch 7:
   3F8737   BU03               05.10.2016 08:08
   3F8737   BU11T               06.10.2016 08:20
   3F8737   EIFEL               04.10.2016 18:51
*   3F8737   GHOST31               22.09.2016 08:19
*   3F87D1   RAPTOR               06.10.2016 07:48
   3F88BB                  07.10.2016 08:37
*   3F88BB   SPIKEO2               04.10.2016 08:21
*   3F88BB   DEMONO2               15.09.2016 14:02
*   3F90F7   GAF242               05.10.2016 06:59
   3F95F2   ATTACK1               10.10.2016 13:24
   3F95F2                  10.10.2016 18:19
   3F95F2   STRIKE1               07.10.2016 08:21
   3F95F2   BU02               06.10.2016 08:56
   3F95F2   GHOST2               27.09.2016 13:46
   3F95F2   NITRO               27.09.2016 18:07
*   3F95F2   GHOST91               22.09.2016 08:07
   3F9768                  10.10.2016 12:17
   3F9768   HG01B               06.10.2016 10:34
   3F9768   HG01A               29.09.2016 17:40
   3F9768   POLICE               27.09.2016 16:38
Final Batch of MIL Backlog. I will start with German small airframes now (In batches of ten unknwons).
*   3F9768   SEAL               19.09.2016 12:04
*   3F98CD   GAF337               25.09.2016 06:45
*   3F99C3                  20.09.2016 17:30
*   3F9A14                  10.10.2016 13:00
*   3F9A14   SW82               10.10.2016 17:58
*   3FA67F   GAF237               10.10.2016 06:32
*   3FA67F                  10.10.2016 08:57
   3FA9FB   BU12T               05.10.2016 08:21
*   3FA9FB   JUSTIS               04.10.2016 08:12
*   3FA9FB   GHOST2               04.10.2016 18:44
   3FB3FB                  10.10.2016 12:18
*   3FBB42   GAF696               10.10.2016 12:03
   3FBD2A                  27.09.2016 13:21
   3FBD2A   GAFE22               27.09.2016 14:19
   3FEEAF                  25.09.2016 12:33
