0 Members and 56 Guests are viewing this topic.
Good Evening Andrew, Wednesdays unknowns:
3D374D  DETER no luck with the details
3DF5AB  DHNHB no luck with the details
German MIL/TAC:
   3E819A  BU11T                                                          2016/11/30 10:56:30
* 3E81F3        2016/11/30 10:41:25
   3E9365  GAF696                                                         2016/11/30 12:50:37
   3E99E7  GAF007                                                         2016/11/30 12:18:53
* 3F4C6F  SPIDER1                                                        2016/11/30 13:35:29
* 3F4C6F  SPIDER3                                                        2016/11/30 17:16:08
   3F60AC        2016/11/30 08:08:23
   3F60AC  SCARE1                                                         2016/11/30 12:54:48
* 3F665E        2016/11/30 17:29:48
* 3F7A73        2016/11/30 08:14:23
   3F8F78  NOBLE                                                          2016/11/30 08:32:39
48C8E2  SPTHC (2x) https://planefinder.net/data/aircraft/SP-THC http://www.airplane-pictures.net/registration.php?p=SP-THC
Regards Ingo
Blueboy
Hi Andrew, picking-up hex A883D0 which decodes as Cessna 510 Citation N648JW c/n 510-0073
J.D
M
Routes:
SAS231N   ESSA   ENVA
SAS232N   ENVA   ESSA
SAS147E   EFHK   ESSA
SAS178G   EETN   ESSA
SAS158E   EETN   ESSA
BCS3613   EFHK   EBBR
BCS3614   EKCH   EFHK
VAS9301   UUWW   EFHK
VAS9302   EFHK   UUWW
VAS9303   UUWW   EFHK
VAS9304   EFHK   UUWW
Operator updates:
VP-BDZ   A319   VIM Airlines
G-FBXA   AT76   Flybe/Scandinavian Airlines System
G-FBXB   AT76   Flybe/Scandinavian Airlines System
G-FBXC   AT76   Flybe/Scandinavian Airlines System
G-FBXD   AT76   Flybe/Scandinavian Airlines System
G-FBXE   AT76   Flybe/Scandinavian Airlines System
OE-GHF   LJ40   Avcon Jet
OE-GXX   LJ40   Laudamotion
OE-GAS   G150   International Jet Management
OE-LPZ   GL5T   International Jet Management
M-GSKY   GLEX   International Jet Management
OE-FID   C510   Skytaxi Luftfahrt
OE-GBD   ASTR   Tyrol Air Ambulance
D-FBSF   C208   BSF Swissphoto
D-IBTI   C525   Berner/Airtrans Flugzeugvermietung
D-CAIR   C560   Berner/Airtrans Flugzeugvermietung
D-ITRA   C525   Transavia Flugbetriebsgesellschaft
D-IPVD   C25A   Transavia Flugbetriebsgesellschaft
D-CGGG   LJ31   Jetcall/Med Call Air Ambulance
D-CSOS   LJ45   Jetcall/Med Call Air Ambulance
D-CDOC   LJ45   Jetcall/Med Call Air Ambulance
B-LDL   GLF5   HK Bellawings Jet
LX-GXX   GLEX   Global Jet Luxembourg
B-09590   B737   Executive Aviation Taiwan
SP-ISS   BE9L   AMC Aviation
SE-LLU   B350   H-Bird Aviation Services
SE-KOL   BE30   H-Bird Aviation Services
SE-RMJ   C25B   H-Bird Aviation Services
VP-CDE   H25B   VipJet
VP-CTG   FA7X   Aviation Concepts
VP-CJJ   GLF6   Jet Aviation Hong Kong
VP-CLR   B737   Lukoil/Global Jet Luxembourg
VP-CLZ   CL60   Lukoil/Global Jet Luxembourg
VP-CLP   GLEX   Lukoil/Global Jet Luxembourg
RA-02787 PRM1   Aviatis
Michel
Andrew,
IBK5881 ENEV-GCLP
VKG1455 GCLP-ESMS
Michel
Northern Watch
Good evening Andrew
A few routes from yesterday and today.
IBK5878.    GCLP - ENBR
IBK5880.    GCLP - ENEV
BEE6GN.     EGPH - EGBB
BEE7LW.     EGPE - EGBB
SWT877.     EGPD - EGNX
AFR273U.    EGPD - LFPG
VKG1517.   GCLP - ENEV
SAS82M.     EGNT - EKCH
LOG28WR.   EGSS - EGPN
Best regards
Keith
orkney
Hello Keith, Michel, Terry, M, J.D and Ingo
That is all of them added/Amended apart from Ingo's two unknown ones.
Thank you once again
Andrew
Morning Andrew,
Not populating : A7AC45
Flight level : 350
Plus :
IBK4YE : LEAL-ENBR
EWG5901 : GCPV-LOWW
X
Andrew
* 1406A4        2016/12/02 08:39:57
* 1406A4        2016/12/02 09:48:23
This decodes to RA-01700 which is Agusta A109S Grand c/n 22123 photographed this year in Brest
X
jacobite
Hi Alan, I have just 1 at the moment.
ACA2025   EHAM-CYYZ
orkney
Hello Ian, X and Ian
Ian EK - I don't know what your Mode S will be. A7AC45 was N594AB, A B734, and it was exported to Colombia. I don't know if  this aircraft is miscoding and has crossed the Atlantic or if it is something else miscoding in Europe. Your routes are done though.
X- That Helicopter is done.
Ian Jacobite - That route is updated.
Thank you to you all once again
Andrew
#7960
Cheers Andrew. Will keep a lookout for that one to see if it returns. Meantime another non populator has come on. It is possibly a new CASA delivery out of Seville :
Hex code : 34514A
Flight ID : CASA 959
Flight Level 190
Also :
AFR524 is LFPG-DFFD-DIAP and not LFPG-OERK-HDAM
orkney
Hello Ian
I would say 34514A is a CASA test reg indeed but I cannot find what one yet.
The route is added though.
Thank you again
Andrew
orkney
Hello Terry
Thanks for that one
Andrew
Michel
Andrew,
BLX07B GCLP-ESMS
CAL73 RCTP-EHAM (replaces CAL65 RCTP-VTBS-EHAM)
CAL74 EHAM-RCTP (replaces CAL66 EHAM-VTBS-RCTP)
DTR271 GCLP-EKCH
PRW326 GCLA-ESGG
PRW640 GCLA-ESSA
VKG1105 GCRR-EKCH
VKG1407 GCLP-ESOE iso GCLP-OSOE
VKG1765 GCLP-ESGG
Quote
ACA2025   EHAM-CYYZ
This was no scheduled flight. This aircraft used to operate yesterdays AC825 AMS-YYZ, but went tech. So departed todays as AC2025.
Michel
orkney
Hello Michel
That is that set done.
Andrew
