0 Members and 54 Guests are viewing this topic.
Good evening Alan, Mondays unknowns:
3CE0F7  DCMMP (2x) that's the only one I was able to find: http://www.airliners.net/photo/Untitled-(SFD-Stuttgarter-Flugdienst)/Cessna-560XL-Citation-XLS/1426332
3D2D75  DEPLT still no luck with the details
MIL:
   3E8968  GAF164                                                         2016/12/05 07:16:12
   3E8968        2016/12/05 10:03:44
   3E8968  GAF164                                                         2016/12/05 10:58:25
   3E8968  GAF164                                                         2016/12/05 12:12:25
   3E8968  GAF164                                                         2016/12/05 13:27:04
   3E8968  GAF164                                                         2016/12/05 14:16:38
3FF0BC  DMYML http://www.flugzeugbilder.de/v3/show.php?id=1149212
3FF482  DMRVT (2x) no further information
3FF563  DMZTA http://www.aviationfanatic.com/ent_show.php?ent=5&AC_Regno=D-MZTA
3FF565  DMWOR I only found traces of this one: https://aviation-safety.net/wikibase/wiki.php?id=161500
4BCA62  TCRSB no further information
506DFA  S5DWW http://www.airplane-pictures.net/photo/736366/s5-dww-private-cirrus-sr22/
71010F  SVA9037 https://www.planespotters.net/airframe/Boeing/777/61594/HZ-AK37-Saudi-Arabian-Airlines
Regards Ingo
No ideas on that one X, not in my d/b, searched the net for both registrations nothing and nothing on LAAS or Rotorspot
Evening Ingo
3CE0F7,D-CMMP,50500360,Embraer EMB 505 Phenom 300,Cirrus Aviation
3FF0BC,D-MYML,C42-0291,Ikarus C42B
3FF563,D-MZTA,3684,Comco Ikarus Fox C-22B
3FF565,D-MWOR,EV97-0209,Evektor EV-97 EuroStar SL
4BCA62,TC-RSB,45-294,Learjet 45,
506DFA,S5-DWW,,Cirrus SR22,
71010F,HZ-AK37,61594/1449,Boeing 777-3FGER,Saudia
Nothing on your others and the mil tac is added
Many thanks
Northern Watch
Good evening Alan
More routes from today:
EZY9005.        EGGW - EGPE
EZY9415.        EGGD - EGPE
BEE1LM.         EGTE - EGPF
EXS001W.       EGPH - EGAA
EXE95G  routes EGPD - EGNT only and not via EGFF as per d/b.
Keith
Hi Keith,
The EZY flight ID's are non scheduled positioning flights or similar as is the EXS flight.
Should that be EZE95G if so it wasn't in the d/b but is now
Many thanks
Northern Watch
Hi Alan
A senior moment, I wrote down EZE and typed in EXE but it is in my db which was updated this morning it is showing 20160510152937 in the CH column.  The strange thing is although it is my db, it did not populate in the routes column in MyLog ?
Best regards
Keith
Cheers Keith.  I believe the EZY's went to Inverness to pick up passengers from fog delayed flights from yesterday
Northern Watch
Hello Alan
Yes, I had forgotten that the 9000 series were positioning flights.  I will delete my record of EZE95G and hope it will populate when I do an update tomorrow.
Keith
M
SAS147C   EVRA   ESSA
SAS188N   ESSA   EFTU
SAS297N   EFHK   ESSA
NTJ3585   ESOW   EFHK
NTJ3586   EFHK   ESOW
APF4284   ESGG   ESNN   via ESSA
APF8773   ESNN   ESGG   via ESSA
Afternoon Alan,
Strange occurrence. Several aircraft appearing on the map showing their speed as 0 kts !
All other details would appear to be normal.
To technical for me Ian but I am sure there will be good reason
Alan,
The speeds seem to be constantly changing. All 8 aircraft on 'My Flights' currently at 0 knots but just been watching AFL2521 go from 371 knots to 0 knots and back again.
#8039
I have none on myflights at 0 knots but all the ones without a globe, not yet with full ADS-B contact but only showing mode c contact don't have any speed showing, once the mode-s signal is received the speed comes up.  All the ones which have made full ADS-B contact are showing 3/400 knot speeds.  The ones with no ADS-B fitted to the aircraft at all don't have a speed showing either as that is not given as part of the mode c signal.
