0 Members and 131 Guests are viewing this topic.
Morning Alan, Wednesdays unknowns:
MILs:
  3E4ECB        2016/12/07 20:02:20
* 3E840E  GAF807                                                         2016/12/07 11:08:41
* 3E840E  GAF807                                                         2016/12/07 13:51:58
* 3EA2FD        2016/12/07 10:10:10
* 3EB57B        2016/12/07 12:51:12
* 3F862D        2016/12/07 19:58:49
* 800BDB  JAI122   VIDP-EGLL                                             2016/12/07 17:17:21
* 800BDB  JAI117   EGLL-VABB                                             2016/12/07 22:12:12
https://www.flightradar24.com/data/aircraft/vt-jew
Regards Ingo
Morning Ingo,
3E4ECB decodes to D-IVAP, nothing on a new allocation
800BDB,VT-JEW,35164/660,Boeing 777-35RER,Jet Airways
Mil tac added
Many thanks
Morning Michel/Alan.
Just to say that speeds of 0 knots are still occurring today.
#8058
Presumably it is a V6 issue and maybe you should advise Airnav that there is an issue with V6 in this respect, it would be the only way to get it corrected.  Is the problem with the software, the stick or the Zadig drivers??  Does it affect boxes or just sticks, I presume it is both and if so I presume it is an issue with the software.
M
APF99   ESNU   ESSA
XMS10   EGKK   EFKT
XMS11   EFKT   EGKK
TCX1359   GCLP   EFKU
TCX1366   EFVA   GCLP
TCX1367   GCLP   EFVA
Michel
Alan,
CND492 GCRR-GCLP-EHAM iso GCTS-EHAM
JTG290 GCFV-EKCH
KLM52R LFLL-EHAM
Michel
Morning Alan,
ISS3740 : LIMC-SBRF not SBFZ-SBSG-LIMC
BAW2633 : LEAL-EGKK needs recycling.
TOM2ED : EGCC-LEAL not EFRO-EGKK
ENT1522 : GCRR-EPWA
superspotter
Hello once again from Lagos;
So, my 88th day here this year.....
Two for you. Hexcode 0641C9 is a CL6 just landed and using a callsign instead of a reg, sounded like "DANA 490". Cannot find anything on it Alan?
Second is Hexcode 43E7EC an A109 which came over the hotel and the reg called was 5N-BSQ. This hex was assigned to M-YHOP and was supposed to go to a T7- reg, but obviously not...
regards clive.
Afternoon Ian, thanks again
Hi Clive,
I am not much help with those two I am afraid
0641C9 I believe will be CL604 c/n 5415 ex N295JL cancelled as exported to Nigeria 25/10 but I can find no details on its new ID
43E7EC went M-AZKL after it was M-YHOP.  My d/b and Rotorspot both show that it should be T7-*** from 1/15 as you state and that's as far as I can get although I would suggest from the hex and the call sign given that it should be 43E7EC,5N-BSQ,22004,AgustaWestland AW109S Grand,(Miscode)
Many thanks
superspotter
Ah, my new Db Alan has this CL604 down as 5N-...
very helpful I know :)
regards clive.
