0 Members and 154 Guests are viewing this topic.
Hi Ian,
Nothing on either of those.  3C488B decodes to D-ABDK which is unallocated as far as I am aware.  There may however have been a transfer within the Air Berlin Group in the last few day as the last D-ABDK became HB-IOS.
Nothing on your mil either
Good Afternoon/Evening Alan, Mondays unknowns:
3C488B  BER917Z
3C488B  BER337U
Seems, that it is back in service: http://www.airfleets.net/ficheapp/plane-a320-2968.htm
3E060D  DHTMJ https://planefinder.net/data/aircraft/D-HTMJ http://www.nordicrotors.com/SE-HPV/476
MILs:
* 3E8447        2016/12/19 15:31:27
* 3E8F58  HAMMER2                                                        2016/12/19 09:15:01
* 3E9C6D        2016/12/19 09:11:03
* 3EB0E3        2016/12/19 13:49:53
   3F55D8  ATTACK                                                         2016/12/19 14:15:31
* 3F563C  DASA07                                                         2016/12/19 13:51:52
* 3F7115        2016/12/19 08:24:24
* 3F7D1A  HAMMER1                                                        2016/12/19 09:00:51
   3F8F3C  NOBLE                                                          2016/12/19 11:17:33
A34B8A  N311LH http://registry.faa.gov/aircraftinquiry/NNum_Results.aspx?omni=Home-N-Number&nNumberTxt=N311LH
Regards Ingo
Today from Heidelberg area:
   000017  STRUT02       again with a flight id.
German MILs:
* 3E8F58        2016/12/20 09:44:16
* 3F55D8  APEX                                                           2016/12/20 14:17:10
* 3F55D8  APEX                                                           2016/12/20 15:26:53
* 3F7D1A        2016/12/20 13:37:41
* 4CA4C0  ABR6TR   LFPG-EDDF-EDDS                                        2016/12/20 05:44:13
ABR: Air Contractors, HEX was once EI-DOZ
US MIL with ADS-B
* AE57A9  1520697                                                        2016/12/20 14:58:43
Regards Ingo
Alan,
I suppose it's possible that HB-IOS has reverted back to D-ABDK. Air Berlin do quite a bit of transferring between the subsidiaries. Libhomeradar have also given it as D-ABDK.
http://www.libhomeradar.org/databasequery/results.php
Evening Ingo
3C488B,D-ABDK,2968,Airbus A320-214,Air Berlin  thanks for the confirmation of the transfer
3E060D,D-HJMJ,0237,Eurocopter EC135 P2+,HTM - Helicopter Travel Munich
A34B8A,N311LH,42.036,Diamond DA 42 Twin Star,Neiling Jem Enterprises
Mil tac added
Heidelberg
Mil tac added
AE57A9,15-20697,,Sikorsky HH-60M,US - Army
No idea on the ABR, corrupt packet??
Many thanks
Ian,
It has definitely reverted back, see Ingo's post
Hi Alan, regarding ABR (Air Contractors):
It was a first time reception with more than 600 messages received.  So, from my point of view not caused by bad packets received.
Supplemental ABR:
In November I got two other airframes operated by ASL Airlines Ireland/FedEx Feeder with the flight id of todays unknown. Maybe a new airframe of the operator.
Thanks Terry,
I presume that it may have been an earlier name or it is one of the division of the European Group.  Google European Skybus and you will get plenty of hits such as https://www.planespotters.net/airline/European-Skybus
and http://www.euroav.com/contact.php
However the Manx register has it as European Aviation I will go with that.
A large number of the entries to the database are made before the aircraft appears on any database or even the national registers and I usually go with the information provided by my information source at the time.
Did you happen to catch its hex Terry, its not in the d/b
Ingo,
Searching the internet leads me to believe it is EI-SLT miscoding but I don't have any confirmation on that.  It should be using 4CA5D1 and is therefore showing plus one for the last three digits.
