1 Member and 27 Guests are viewing this topic.
Hi Jason
A3448E decodes to N31AX which is not allocated by FAA
I have noted that all their fleet are owned by Blue Sky Investments now, looks like they have done some sort of sale and lease back or similar as I am sure they were just Woodgate Aviation previously or at least the PA31's were.
Hi Alan
MON544 - EGCC to GCRR
MON545 - GCRR - EGCC
Good Evening Alan, Yesterdays unknown from HD area:
German MIL/TAC: 3F5E68  GUNNER
Regards Ingo
Yesterdays unknowns Hannover:
MILs:
* 3E9FE5  ACES4                                                          2017/01/11 08:49:28
* 3F523B        2017/01/11 08:48:24
* 3F523B        2017/01/11 09:56:38
* 3F5F35        2017/01/11 09:31:53
* 3F5F35  SW03T                                                          2017/01/11 10:30:05
* 3F5F35        2017/01/11 14:06:28
* 3FBC2C  GAF640                                                         2017/01/11 11:57:42
* 3FBC2C  GAF640                                                         2017/01/11 14:05:42
Todays unknown from HD area:
* 3E4EBC  DIVAA                                                          2017/01/12 08:34:25
* 3E4EBC        2017/01/12 15:31:26
no luck with the details
Many thanks Ingo, all done
#8530
Thanks Alan,
I presume, that you don't have any information about D-IVAA either?
EDIT: * 3E9FE5  ACES4                                                          2017/01/11 08:49:28   hasn't populated
Hi Ingo,
Didn't see that post, nothing on D-IVAA yet although it flew Stuttgart-Hesse and the mil tac done this time.
#8532
Terry,
That is not a registration, military aircraft use serials in this case 010 and not registrations, F-RBAC is its fleet number/code. You will not find F-RBAC is the French register for example.   In French military use the aircraft serial is the same as the c/n and is the same for most of their aircraft.  If you want to use it as its registration instead of its serial in your own database, please feel free.
http://www.airliners.net/photo/France-Air-Force/Airbus-A340-211/4115869?qsp=eJwtjcEKwjAQRH8l7FkPInjoTX9AD/7AsplqsDZhs2BD6b%2B7Bm%2BPN8PMSpJnw2L3VkADVbDKk3ZUWPldaVjphfbJGp1pVJ4FYR84aRizCrxZs9qleRrZcBZBMcS/v2qE/iJU6aMPPzk4QG%2Bd6XhyH1MtE/cNGKeJtu0LrWoy4g%3D%3D
#8533
Terry,
I do not intend to put codes/radio call signs etc into the serial fields and to ensure standardization I will ensure all aircraft show their military serial and not their quasi-civil code where this has been entered as an error.  Other Air Forces are similar in having a military serial and quasi civil registration displayed, Egypt is an example.
Mainly military enthusiasts would be up in arms at using incorrect detail.  Where will it all stop, next someone will want to add the codes for Typhoons, Tornados etc.  If you need the photo you can download it yourself into your photo folder and name and show it to suit your personal needs.  As you don't use the database but maintain your own based on what you pick up this should not give you any issues.
#8534
Cheers Terry, I agree to differ with you on this.
When we started on the database the forum members were asked their opinions.
